Kenmore ultra fabric care heavy duty washer 80 series
The washer washes for a short while then stops. If I try again later it does the same thing. Pleas help.
  • Anonymous Dec 19, 2008
    i cant get hot water only cold
  • lu123 Jan 17, 2009
    I'm having the same problem
    Genius:
  • 1,239 Answers
Hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Posted on Sep 13, 2008
    Genius:
  • 1,122 Answers
SOUNDS LIKE YOU HAVE A PROBLEM WITH YOUR TIMER,DOES THE TIMER STOP IN THE SAME SPOT ALSO?MIKE
I have a kenmore ultra fabric care washer heavy duty 80 series with electronic temperature control and I can only get hot water not cold.
If it used to work and now does not, either the valve that controls the water inlet to the hot is bad or the temp sensor in the machine is bad. What is the whole model number?
Mar 22, 2015 | Kenmore Washing Machines
Is there a belt on a kenmore ultra fabric care heavy duty 80 series
No. What is the problem you are having? Let me guess, it's not spinning or agitating?!
What is the model number listed under the lid?
Nov 03, 2012 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore/Ultra Fabric Care IV - Heavy
Sounds like the machine is stopping to me, could be the off balance switch at the rear off the machine. You should know if its getting to the spin cycle.How wet are your clothes ? Hope this Helps.
Sep 15, 2009 | Washing Machines
Direct drive-type Kenmore washer will not spin.
Check the video at the following link. I think you will find it helpful. Hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Sep 14, 2009 | Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Washing Machines Logo
1,110 people viewed this question
Top Washing Machines Experts
