Question about Sony PlayStation Portable (PSP) Console
About error 80020148
It says change to 4.xx kernel
then .....
how/& what do u change to do this?
  • 1 more comment
  • Reaper00 Sep 18, 2008
    lol ima fool ok well i forgot bout dis post
    im following a reallly goood guide for installing cfw
    it dosent matter to u its 4.05
  • g-dex Oct 23, 2008
    i get 80020148 when i try to put a cfw
  • bysk May 11, 2010
    What firmware are you running? Version and Custom/Official will be helpful.
    Problem Solver:
  • 31 Answers
Just remember... if anything goes wrong, there's always a Pandora's battery to help you!
Posted on Sep 18, 2008
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
My psp has an error code 80020148 when i try to play iso games
* 80020148 = PRX type unsupported
Explanation: This error comes up when you try to use emulators, homebrew, etc. on a psp with version 1.52 and higher.
Apr 19, 2010 | Sony PlayStation Portable (PSP) Console
ERROR 80020148 i own PSP-1001 with fw 5.00 m33-4 i am able to some of the cso games like nfs shift,tigerwoods pga-10,virtua tennis-3 bt few like fifa 10,smackdown2010,metal slug etc.. show the error 'game...
hold the right shoulder button and turn the system on. it will go into the recovery menu. select configuration and goto umd mode. it will say normal UMD required. press X and it will change to M33 driver. now select back and then exit. system will restart. ENJOY!!!!
Jan 03, 2010 | Sony PlayStation Portable (PSP) Slim...
Hi good day, my psp is also having the error 80020148 i tried those two solutions you have posted but none of which seems to works, im using version 5.00 M33-6 please help, i need your advise on this...
TO FIX THE PROBLEM FOLLOW THESE STEPS:
1. Goto Recovery Menu (turn off then hold R and turn on)
2. Configuration -> Use NO-UMD (Disable it)
3. Go all the way back to main menu
4. Advanced -> Advanced Configuration -> (Disable all of them)
Configuration Should be Like This ->
.....................1. Disabled
.....................2. Enabled
.....................3. 1.50 (for Phat but needs 1.5 kernel addon) 3.80 (for Slim)
.....................4. Disabled
.....................5. Normal (Needs UMD game to play Isos) if not try Sony Np9660
.....................6. Disabled
.....................7. Enabled
.....................8. Disabled
.....................9. Enabled
.....................10. Memory Stick
.....................11. Enabled
.....................12. Disabled
Advanced->
.................Advanced configuration->
.................................................. .Disabled
i hope this might help you
Nov 28, 2009 | Sony PlayStation Portable (PSP) Slim...
ERROR 80020148
well, first off... no one likes hackers.. second, just look up on google.
Nov 21, 2009 | Sony PlayStation Portable (PSP) Slim...
I decided to switch to ubuntu 9.04 os but i have problem with dial-up connection using Dlink 562is modem.
1. Install hsfmodem_7.60.00.09full_i386.deb from terminal
* type sudo dpkg -i *.deb
* Where is the linux source build directory that matches your running kernel?
* [/lib/modules/2.6.20-15-generic/build] press Enter
* Please enter region name for modem unit 0 [XXX] : type country name then press enter
* Please enter your email address [unknown] : type your email address then press enter
* Recorded The registration ID for modem unit 0 is: XXXX-XXXX-XXXX
* Please enter license key [FREE] :
2. Open new terminal, type ./genertor.pl [email address] [Registration ID]
3. get key: XX-XX-XX-XX-XX-XX
4. enter the key on Please enter license key [FREE] :
5. Copy hsfpatch to /usr/lib/hsfmodem :
* $ sudo cp hsfpatch /usr/lib/hsfmodem/
6. Execute patch file : $ sudo ./hsfpatch
* file 'modules/imported/hsfengine-i386.O' openend
* patching... done
7. Reconfigere hsfmodem : type sudo hsfconfig
* Press ENTER for all the questions
* Would you like to keep using them? [no]
* Please enter region name for modem unit 0 [XXX]:
* Please enter your email address [XXX@XXX.com]:Please enter
* license key [XX-XX-XX-XX-XX-XX]:
8. Reconfigure hsfmodem complete :
* Config for modem unit 0: /dev/ttySHSF0
* Device instance: 0-PCI-14f1:2f30-14f1:20d5
* HW revision : Basic2 2.18 Standard DAA 3VoltsIA
* HW profile name: hsfpcibasic2hsfi
* Registration ID: XXXX-XXXX-XXXX
* License owner : XXX@XXX.com
* License key : XX-XX-XX-XX-XX-XX
* License status : OK
* Current region : XXX (T.35 code: 0054)
* The /dev/modem alias (symlink) points to ttySHSF0
9. Install KPPP
10. Browse The World
Jun 17, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
Psp
First Tell me about your PSP firmware Version. If its a orginal SONY firmware you can't play the games from the memory stick. If you are in custom firmware follow this procedure.
1.press the SELECT button so you will get the M33 VSH MENU
CPU Clock XMB - Default
CPU Clock GAME - Default
USB Device - Memory Stick
UMD ISO MODE - Sony NP9660
ISO VIDEO MOUNT - NONE
Make sure that its showing as per the above values. if not change it to the above values.
If still the problem continues check these too..
Go to the recovery menu.>>> configuration >>> Game folder homebrew (currently: 3.XX or 4.XX kernel)
if its showing 1.50 change it to 3.xx or 4.xx
also
Go to Recovery >> Advanced >> Advanced Configuration
and make sure that both the options are Disabled.....
Jul 24, 2008 | Sony PlayStation Portable (PSP) Console
Turn the xbox on and where the light is green there is only one red light and it says on the screen system error
An original Xbox? On the error screen there should be a number. Which is it?
2 - bootldr - Eeprom check failed
4 - bootldr - Ram check failed
5 - kernel - HDD not locked
6 - kernel - Cannot unlock HDD
7 - kernel - HDD timeout
8 - kernel - No HDD found
9 - kernel - HDD parameters (
10 - kernel - DVD timeout
Actually its almost the same as error 6/7/8.
11 - kernel - No DVD Found
12 - kernel - DVD parameters (PIO/DMA)
13 - kernel - Dashboard launch fail
14 - dashboard - Error loading dashboard
16 - dashboard - Clock cannot be set.
20 - kernel - The dashboard was attempted to load and failed
21 - anywhere -
Some of these are relatively simple to fix. Some are nightmarish. Let me know which it is and maybe I can help you.
Jul 10, 2008 | Video Game Consoles & Games
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Sony PlayStation Portable (PSP) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
