SOURCE: SHARP LC 32GA8E
Have disconnected DVD player and it seems at this stage to have corrected the problem. Early days and so I am just keeping my fingers crossed that the problem was with the DVD player and not the TV.
SOURCE: my pc get over heated & suddenly get off
It seems you might get a faulty laptop, you should make use of your warranty and avoid turning it on again since it could get damaged for good. If it turns off as soon as it gets to hot is because the system works that way so your processor or motherboard wont get scorched. If you keep working on it, every time it reaches any high temperature all of its components get worn and the life span of it get decreased. The best solution is to return it and get it changed, because as far as I know its a reliable laptop. Good luck!
SOURCE: Frozen samsung TV - wont turn off
since you say you have had it just a short time
call samsung and request service for your set this is a problem and will get worse
if its just a couple months old parts are still in warranty and not sure of labor there is a warranty statment in the owners manuel
