Question about Sony STR-DB930 Receiver
Speakers Cutting Out
Hi. I have had my STRDB930 for a few years. The rear speaker relay started cutting in and out, making a rapid clicking sound every so often. Sometimes the rear speakers would be off for ages before clicking back on. Recently, the centre started doing the same. I have re-soldered 4 solder joints underneath the main board that I can access via the removable panel on the bottom, which looked like dry joints. These were on the blue relay units mounted on the lower board. The remaining blue relay, mounted on a board higher up, continues to click on and off, I can't gain access to this board. I am unsure as yet if I have fixed anything, as I only soldered the dry joints yesterday. Has anyone else had this problem?
    Problem Solver:
  • 15 Answers
I posted this solution on FixYa to help someone who had the same problem, or at least a similar problem. If you remove the slotted panel underneath the bottom of the receiver, you can gain access to the underside of the main circuit board. There are 3 relay units there, they are blue boxes that can be seen if you shine a torch down through the top. I found the solder joints on these relays looked as though they had broken away from the board, there appeared to be a dark ring around the pin of the relay. I re-soldered 4 of these connections, and, so far, that seems to have done the trick. Time will tell. These relay units connect and disconnect the speakers. There is one other relay that is mounted on a seperate board above the main board, that I can't access easily. If this one is also faulty, I will be un-able to fix it, as it would involve removing the entire guts of the receiver. If any of your technical team disagree with my remedy, or can offer any other solution, that would be appreciated. Thanks.
Posted on Sep 15, 2008
Rear Speakers cutting out
You Need to Change Wire Connected to Speakers. it's may be damaged internally.
Mar 15, 2014 | Panasonic Audio Players & Recorders
Hi I was wondering if You could give Me an explanation to Why My speakers May not be working. They are not bent or cut on any cord and the rear right, rear left and front center all have stopped working...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 27, 2011 | Logitech X-530 Computer Speakers
Speakers have been working fine for a couple of years, suddenly cut out and im not sure if they are broken or not, have all the updated drivers, have tested other speakers so its not my sound card.
also
hope this helps
Mar 21, 2011 | Labtec Spin 55 Computer Speakers
Hi, i have a marantz pm720 amp, when i switch it on, straight away it starts to make loud cracks through the speakers like spikes,then it will cut sound all together for a few seconds then back on, when i...
Hi Paul;
There are one or more transistors failed in the output circuit
I would have tech look at the amp and see what the power supply is doing without spkrs connected
Aug 20, 2010 | Marantz PM7200 2-Channel Amplifier
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
STR-DB930 Receiver
Hi. I have a similar problem, where the rear and more recently, the centre speakers cut in and out. The relays that connect them click on and off rapidly, like morse code! Annoying, especially losing the centre, as in a 5.1 mix the centre carries most of the dialogue. The voices will be very hard to hear without the centre speaker. I tipped my STRDB930 over, and removed the slotted panel under neath. This gains access to the under side of the bottom circuit board. There, you will find the solder joints of the 3 bottom relays, the fourth being mounted on a narrow strip of board above this. Shine a torch through the top onto the blue relays, and you will see where the solder joints are. I noticed that 4 of these joints looked like they were broken, so I re-soldered them. The centre seems ok now, although it's too early to tell. My receiver still clicks, but if that is comming from the relay mounted higher up, I don't know how to gain access to this easily. Hope this helps.
May 01, 2008 | Sony STR-DB930 Receiver
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
Centre and left speaker cutting in and out
Hi. I have a SONY STRDB930 receiver and the rear speakers started cutting in and out, with a clicking sound. Eventually, the centre channel followed suit. I turned the receiver over and removed the slotted panel on the bottom. This allows you to access the circuit board, where you will find the solder joints belonging to some blue relays that you can see down on the bottom if you shine a torch in from the top. Check these, as I found 4 of them appeared to have broken. The solder blobs should appear shiny, without any dark ring around the pin. If they look dodgy, re solder them. I did this, and it appears to have fixed the problem, at least for now. These relays are what is clicking, and they turn the speakers on and off. If the voltage supply to the coil of the relay is interupted, by a faulty solder joint, for example, the relay will cut out.I hope my solution is not too late for you, I have only just gone online recently.
Feb 06, 2007 | Sony STR-DB930 Receiver
Sony STR-DB930 Receiver Logo
411 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
