Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wont go down
The door will operate from the inside only if I hold the button down continously till it reaches the bottom. If you use the remote from the car it will not function at all. It seems like to me that the sensors are malfunctioning some how. If I let go of the button and the door is not all the way to the bottom it retracts and goes back up.
  • Anonymous Mar 22, 2014
    remote will make door go up but not down and you have to hold button on back of unit to make it go down
Posted on Sep 14, 2008
    President:
  • 1,901 Answers
I had the same problem with my daughter's garage door. The problem indeed was the sensors at the bottom of the door which protects kids, pets, etc. First, make sure the wires are connected to the properly color-coded screws on the unit. I believe one is white and the other has a black stripe. Of course the sensors have to be aligned. If properly connected and aligned there should be a green LED on BOTH sensor units.
Posted on Sep 13, 2008
My garage door all the sudden stopped going down when I push the button once...I have to hold it down
SEnsor issue. If not hooked up properly or something is in the way, the door will not close unless you push and hold button till it closes.
Aug 28, 2017 | Building Materials
2001 Chrysler Sebring is there anyway manually to put up a power window
Have someone push button at the same time pull top of window up. Or rake door panel off and reach inside door and push bottom of window up while pushing button
Apr 26, 2015 | 2001 Chrysler Sebring
How do i program a avol ma001 remote control
On the average remote you can have the remote find the code. Hold down search button till light blinks than select what you want to operate.hold that button down till it blinks and stays on. With device turned on keep hitting the off button till it turns off .As soon as it turns off hit the inter button.
Dec 19, 2014 | Televison & Video
Power windows will not go up or down
Try holding the button in the down position till window reaches bottom hold till it clicks a couple of times then pull the raise button up and hold it till it reaches the top and clicks a couple of times, that should reset the switch.
good luck.
Mar 16, 2014 | Chevrolet Colorado Cars & Trucks
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
The back door won't unlock or open and the front doors won't unlock by the remote
Simple enough to reset the power locking system:
1) make sure battery in remote is good, if in doubt replace it. Next unlock all the doors and keep them closed.
2) Jack up the car and you'll find the power lock reset button above the fuel tank. If you cant reach it drop the tank down slightly until you are able.
3) Depress the power lock reset button, then get inside the car and hold the unlock button on the remote for 2 min.
4) The system will reset when you get out of the car and hold the lock button for another 2 min while circling the car briskly.
Jul 02, 2010 | 2002 GMC Safari
Remote does not open or close garage door; inside button flashes
What has happened is that you electric eyes are blocked or have gone out. The eyes are at the garage door about a foot of the ground on both sides. There should be a red or green light on one of them. If not some thing is blocking the beam that goes across the door. It is a safety beam so kids can nt get hurt when the door is coming down. If the beam is broke the door will go back up.
Jan 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
182 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
