I have an NEC LCD1760VM monitor and the light in the monitor comes on when the power is turned on and then immediately goes back off.
You can try to replace the capacitor C845 on the power board, 470uf 25V. You'll know if it's bad if the top of the cap is 'bulging'. It may also be seeping a paste or liquid (the dielectric)
Radioshack sells a 470uf, 35V cap for $1.37 and it will work fine.
Posted on Apr 10, 2009
    Guru:
  • 1,342 Answers
Try unplugging it from the wall outlet for awhile to re-set it.
Posted on Sep 13, 2008
Monitor comes on and then immediately goes dark goes off
Your monitor's power supply is probably bad. If your inclined, you can pry apart the monitor shell and replace any bulged capacitors you see on the power supply. Replacement capacitors are available from mouser.com.
Mar 30, 2013 | Computers & Internet
How do I stop system notification pop ups?
not sure what system resolution box is it must be popping up for a reason
if you right click in the bottom toolbar / taskbar select task manager applications you will see what running also under processes the same if you something you dont need to be running select end now
hope it helps you
Feb 13, 2012 | NEC MultiSync LCD1760VM-BK-1 (Black) 17...
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Oct 29, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Jun 27, 2007 | NEC-Mitsubishi Nec Display Solutions...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
