Question about ASUS Computers & Internet
Asus A8N SLI DELUXE MOTHERBOARD AMD PROCESSOR
COMPUTER WILL NOT TURN ON. HAVE CHECKED POWER AT WALL, CHANGED POWER SUPPLY, CLEANED BOARD, REMOVED AND REINSTALLED PROCESSOR AND ALL CARDS
  • Anonymous Oct 05, 2008
    Just purchased (new in box) ASUS M3A78-EMH HDMI. Have a ATX 400w 20-pin and 4-pin power plug PSU but computer will not power up. The Onboard LED is green so power is good. Manual indicates unit must have at least 15A on +12V and power rating of 300W. My power supply is 17A on +12V and power rating of 400W. This should work, but isn't. Any suggestions other than going purchase another PSU?
  • Steven Brown May 11, 2010
    When you say removed and reinstalled the processor are you saying you simply removed the CPU from it's socket ?
    The reson I ask is because you COULD still have a defective CPU or dead motherboard.
  • 67 Answers
When you reinstalled the processor, did you put thermal compound on it? Not putting thermal compound on an AMD processor could burn it. I've tried this before, thinking it was okay since i tried an Intel not placing any thermal compound, and there was burning smell on the AMD processor. If the problem before was the power supply, you might also want to check the motherboard. Defective power supplies destroy the motherboard as well. You may also want to check the if the power button was placed back to its pins. You may have missed that or the wire might have come loose.
Posted on Sep 16, 2008
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
A8N-SLI Deluxe asus motherboard wont boot
first you want to make sure
the power supply works, they can stay on for a week then die, then work again , then die
then disconnect the cd rom, and see if it still has the same problem,
next could be the processor , this would be the cheapest part next in line,
processors get warm when they work
if not , you would replace that before motherboard
you can also disconnect the hard drive a while
to make sure there are no config errors
Jul 21, 2009 | ASUS A8N-SLI Deluxe Motherboard
Power supply not coming on
first of all you need to connected the power supply connector, processor connector, hdd connector, cd rom connector.
check it
Jan 21, 2009 | ASUS A8N-SLI Premium Motherboard
Firewire problem
http://support.asus.com/download/download.aspx?SLanguage=en-us
this site has a list and downloads for your motherboard drivers could not see firewire that may be in packaged in one of the other drivers
Jul 31, 2008 | ASUS A8N-SLI Deluxe Motherboard
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Asus A8N-SLI Deluxe Problems Booting
Sounds like the power supply is overloaded. Is this a new configuration? Start removing components until it powers up. If it still doesn't power up, check to ensure you don't have a short in any of the connectors that you installed components into. Sometimes when a video card, memory DIMM, or whatever, gets installed, there is a chance that a connector pin will get crushed and short out to nearby pins. If none of those work, you might want to try a larger wattage power supply. Good luck.
Nov 24, 2006 | ASUS A8N-SLI Motherboard
Computers & Internet Logo
195 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
