Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water dispenser My well developed sulfur in the drinking water. The well has been flushed and the problem is corrected. However, I can not get the sulfur out of the holding tank in the refrig. Can it be removed and cleaned?
    Genius:
  • 1,122 Answers
SORRY,NO,MIKE
Posted on Sep 13, 2008
Mayo clinic says drinking water will prevent heart attacks?
It is true few people are correctly or sufficiently hydrated enough for peak health but drinking too much water is as dangerous as drinking too little.
Being properly hydrated is good for health as part of a healthy lifestyle and a healthy lifestyle can be a way to avoid developing heart disease. I don't think drinking water would be able to reverse the effects of heart disease.
Further information and a discussion about this might be found on ehealth.com
Apr 13, 2017 | Health & Beauty
Glacier Bay Water Dispenser
If this is a new unit, I would take it back. If not new continue with the cleaning process. Making sure it is thoroughly flushed and that clear water is exiting the dispenser. Plug it back in and continually check on it. If water turns again, I would flush system again and when finished supply water but not plug the dispenser in. Monitor to see if the water turns color. If not then you know that the heating portion of the unit is causing something to leach out into the water. I such case I would not drink the water. There are no replacement parts for this dispenser.
Jul 14, 2016 | Plumbing
What are the benefits of drinking water in the Morning??
drinking water in the morning has a number of benefits for your overall health of body and mind.
  • It helps you to re hydrate your dehydrated body.
  • It helps your body to flush out toxins.
  • It fires up your metabolism.
  • It fuels your brain.
  • Keeps you regular and relieves constipation.
  • Prevents and cures many disease.
  • It is completely refreshing.
Feb 08, 2016 | Water Dispensing & Filtration
Egg smell from hot water
You either have water with a high sulfur content or need to flush your heater. you should flush your heater every year anyway. you can turn off the water and electric to the heater. and totally drain the tank when it is totally drained add more water and drain some more. then refill the tank and run a hot water faucet the tub is best to eliminate any air in the system then turn the electric back on this should solve the problem if it does not you probably have sulfur in the water and would need water treatment or filters to help
May 06, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rotten egg smell
Do you have sulfur in your drinking water? Or is this just a comment that you have too much sulfur in your diet? :)
Nov 28, 2013 | Plumbing
Can drinking water with lemon prevent kidney stones? Also, I have been told not to drink city water. What is the best water to drink?
Yes, I do believe that it is true. Drinking water is always good and can help to improve our health and hygiene as well. It increases energy and relieves Fatigue, helps to promote weight loss, Flushes out toxins, maintains regularity and moreover is a natural headache remedy as well.Adding a pinch of Lemon to it has proved to remove Kidney stones as well. This can definitely be tried out!.
Aug 27, 2013 | Refrigerators
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
How to fix a sulfur smell from hot water side of faucet.This started when we replaced an old faucet with a new one.
Probably coincidence, but that sulfur smell is likely from your water heater.You'll either have to shut-off power, or gas, to water heater, and drain it down, then re-fill it, or leave hot taps on, and let it flush itself out. If you have a way of introducing bleach to line coming in to house, such as a pump or something , you can do that to help flush that smell out of water heater, otherwise, flushing or draining may be your only option.
Jan 07, 2010 | Delta Victorian 2155-SSLHP Bar Two Handle...
Filtered water
what kind of supply line is going to the dispenser,, if you have well water you might want to think about even another filter in the line before the frige, change the supply line to copper if it is copper change it to another copper line,,, there is no reason for it to only happen to the ice maker,, what about the ice bucket and ice tray:{where the water fills to make the ice} try cleaning these also
Aug 04, 2008 | Maytag MFD2561HE Bottom Freezer French...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
59 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
