Question about Balance A535 notebook 14.1 LCD Hinges (BALANCEA535HINGES) CD-ROM Drive
Wireless Problems! I have a Balance A535 laptop, and I had a wireless card put into it about a year ago. I was able to use the internet up until yesterday evening. It says that a Network Cable is Unplugged... I've gone into the control panel and tried to set up a new connection, and its just not working. I also went to the Wireless LAN Settings in the control panel, and it says it is "Unable to connect to the Wireless NetCard. Is it inserted?" ... Could the wireless card just die on me? There are two other computers running off the same internet in the house, and we've never had a problem before. One of them is hooked directly to the modem, and one uses the Wireless Router... Please Help!! Oh and I'm using Windows XP
  • 19,396 Answers
The computer looks for the cable because wireless is not working.
If wireless card is usb try removing laptop battery, unplugging power adapter and wifi cards, connect in five minutes and see if it works
If it still does not work, reinstall wireless card drivers.
If you have a disk reinstall them from disk.
If you lost the disk download drivers from the Internet, post model on fixya to get the link.
If the wireless card does not work after reinstalling drivers then it is probably faulty.
Note: if you use laptop internal wireless, usually you need to activate a switch to get it working.
Posted on Sep 13, 2008
My new Lenovo G550 laptop (bought 3 days ago) won't connect to a wireless network anywhere. At home I have a desktop and another laptop that are connected and I don't have any trouble with them until I...
The wireless card may be swithed offGo to control panel and select "wireless connection" windows will detect the wireless card and tell you if it's swithed off.
Sep 11, 2010 | Computers & Internet
Technical support
you need to open your WIFI to connect
i hope i can solve your problem
Sep 03, 2009 | RPM DK23FB-40 - Balance 40G(5400RPM) For...
How do I get my Balance Laptop model A535 to be wireless?
There are three possible ways. 1. If the notebook has an available miniPCI socket in a compartment on the bottom of the PC, a wireless card can be installed there. However, the antenna wires are nearly impossible to connect. I would pick one of the following: 2. Get a wireless PC Card for notebooks, or 3. Get a USB wireless device (works on notebooks and desktops. This option is easiest, and usually cheapest. Follow the instructions that come with it, and you're all set. I use a USB wireless device when I work on PCs, to get out to the Internet and download drivers and such.
Mar 04, 2009 | Computers & Internet
I am a technician assisting in the repair of an A535 notebook, can't seem to get the wireles network card to work, can you assist?
Is it a built in card in a mini PCI slot? .... I had one die not long ago ... didnt show any problems in device manager ... the status light was on ..... it just didnt work.
Replacement with a new card was the only option.
Jan 02, 2009 | EliteGroup ECS A535 Notebook
Battery
Wal Mart had them on line for $79.00, but are out of stock at this time, found on line stores 139.85 shopbatter.net and 139.95 laptoppartsnow.com put in google search Balance A535 replacement battery.
Dec 25, 2008 | Balance A535 notebook 14.1 LCD Hinges...
Wireless Problems!
Sep 13, 2008 | Computers & Internet
Balance computer laptop
Will not stay connected to wireless.
Sep 02, 2008 | Balance CN6555 Notebook
Balance A535 laptop
THE FAN IS SHOT FOR A a535 MODEL, WHERE CAN A NEW ONE BE PURCHASED?
Aug 10, 2008 | Balance A535 notebook Cooling...
Errors
uninstall the drivers for the wireless card then run windows live update the wireless card should be found and the drivers should d-load and then install themselves if that doesn't work try resetting your router or modem for the internet... sometimes certain computers in a house will receive a signal, and you might get the signal as well but the computers are messing around with the wireless... this happens more with belkin routers just restart the router and just run that one computer on the wireless network and it should start working. then you can allow all the other computers back onto the network
Jul 23, 2008 | Averatec 3200 Notebook
Balance A535 internet access problem
ok listen it could be 1of 3 things that could be the prombelm we run into this prombelm often when you have used a vareity of hook ups for it . need to go to start button click it go into control panel go to network conections delect or unistall all icons as far as you can.Lets start from the begining ok you said you have wireless connector in your pc already which is good ok just need to go threw process to conect it I am supposeing you have xp
if not you need to contact me ok ,first off need to go to control panel click on internet options go to connections check in the three postions and make sure the dot is filled on never dial a connection,then scroll down to lan settings click on it make sure
that it has a check on automatically detect settings.ok first part
is done (boot computer off one time) reboot it and then go to
connection wizard go threw process to make a connection to
internet (what ever you do read it carefully ) do not put any kind od telphone or cable settings make sure it says wirelss connection finsh wizard and the make sure you reboot when all process is finshed that will lock it in ok then go to your internet explorer make sure it doesn't have a check mark on offline then
it should connect if not call me or send a chat and i take threw step and step process to connect ...lala linda
Jun 05, 2008 | Balance CN6555 Notebook
Computers & Internet Logo
252 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
