Question about Dell Inspiron E1505 Notebook
AC adapter not recognized
Have had my dell inspiron 1525 about 2 weeks - just booted today and got the error message that the ac adapter was not recognized - any help is greatly appreciated - thanks!
  • 3,940 Answers
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
Check the inside of the connector, since it is new, you can call Dell 800-624-9896 for a replacement adapter.
Posted on Sep 14, 2008
  • H A Franklin Jan 18, 2011
    If Dell QuickSet is installed, uninstall it.
  • Mohammad Abuzeid
    Mohammad Abuzeid Jun 30, 2013
    its not fixed ithink there some software can force laptop to recgnize the charger because chrgers physically runs fine and give exact power out
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Have a dell inspiron with original ac adapter and battery. i get error message saying that the AC adapter cannot be determined is not recognized by dell and need a dell 65W AC adapter. I have the...
The adapter could be faulty or has failed slightly and is below the operating limits. This means you probably need to replace the power adapter.
Nov 01, 2010 | Dell Inspiron 1501 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Sep 29, 2009 | Dell Inspiron 1545 Notebook
Dell inspiron 1525 will not charge the battery
This problem has arised because your motherboard hasn't identified your battery. So, this is motherboard problem.
next time when you chat with the dell representatives, tell them that your motherboard is not recognizing your battery. They would arrange a pickup and would have it repaired in their center.
Good luck,
Jun 03, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
If you don't get any errors when you startup on battery then all you have to do is call Dell. Get work order number and send them the laptop and adapter. They are very fast. I sent a laptop to them last month and I had it back in 3 days! I was surprised.
Dec 04, 2008 | Computers & Internet
Dell Inspiron E1505 Notebook Logo
1,349 people viewed this question
Alun Cox
