When i turn on tv it keeps shutting back off - Televison & Video
  • 1 more comment
  • jane1260 Sep 13, 2008
    tv shuts off as soon as i turn it on
    I tried unplugging it for over an hour the tv still shuts right off as soon as i turn it on i don't know what fuses to look for how would i know if they are blown? it's a mitsubishi i'm lost
  • jane1260 Sep 14, 2008
    thanks for the help
    President:
  • 624 Answers
Your TV is going into what is called the "protect mode". There are a variety of reasons it can do this. None of the reasons are anything that can be fixed without having some kind of electronics knowledge and the proper test equipment to figure out just what is causing it. You have mentioned that you do not know how to find or even check the fuses in the TV. This would indicate that you would need to have the TV serviced by a qualified service technician.
Please just follow this link and you can find a service center for your Mitsubishi TV:
http://direct.where2getit.com/cwc/apps/w2gi.php?template=search&client=mitsuservicer#?mid=174138
If you cannot click the link, just copy and paste it into your internet browsers address bar. You will save yourself money by not trying to fix the TV yourself, since you have no experience doing these type of repairs. It is very easy to cause more damage than you have started with if you are not familiar with how to troubleshoot a TV. it is also very dangerous to attempt this since TV's have some very high voltages inside of them. Do yourself a favor, get a qualified service technician to check it our for you. In the long run, you would be much happier, safer, and save yourself money.
Dave
Posted on Sep 13, 2008
  • 2,071 Answers
The condition of your TV called power supply overcurrent shutdown. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating .I would probably also check the flyback circuit and flyback transformer although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
    Genius:
  • 2,920 Answers
You have a power supply problem you need to have a tech fix it the power supply is bad
    Genius:
  • 1,239 Answers
Hi Did you check the small fuses and resistors near to the convergence ICs? if they keep blowing there is a powering problem on the convergence board.
  • 19,396 Answers
That is the internal safety switch, that detects a fault and keeps tv off.
Try first unplugging power cord for one hour.
If it does not work it means that there is an internal fault, probably a faulty component or a board in need of replacement.
If you need to call a technician you can ring the phone number listed on the owner manual.
If there is an error code post here
  • Ginko
    Ginko Sep 13, 2008
    The only fuse that is easily accessible is the one in the power supply, and that fuse is ok, when it blows you get no power at all.
    The tv components must be tested thoroughly, for that job you need a technician.
    If you get an error code we can find out what the problem is.
    Let us know TV make and model, and if you get the light flashing any number of times.
DLP keeps shutting off
Check Lamp Fan or Fans and it could be that the Lamp is going out.
Oct 01, 2012 | Zenith Z52SZ80 TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
The tv keeps shutting down
i unplugged the tv , turned the lamp switch to off . I left it unplugged for a few hours . I then plugged the tv back in , hit the reset button , located on the front bottom left . I waited for the timer light to stop blinking , then turned the lamp switch to the on position . I turned the power on to the tv . i heard the fan kick on , this time there was not a dragging sound . the screen lit up and i have not had a problem since yesterday . i think that the problem started because the tv had been left on for too long , I know that what i have done is only a temperary fix . but as long as I dont forget to turn the tv off , i should not have a problem
Mar 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Phillips 43p8341 tv keep shutting off
some of the parts you can find online some you cant.it aounds more like the power supply than anything else
Oct 05, 2007 | Philips 43P8341 43" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
