Try by replacing new SCREEN or the connector (pata) of the Board else refer to the nearest mobile service for servicing. Because they may have a spare part(s) of handset.
2 Solutions Possible.
The connection between the LCD Screen to the motherboard is not connected well and is causing the issues you are having.
OR.
The screen itself needs to be replaced because it defective.
I would try a battery pull if you haven't already. It's most likely moisture damage, I would remove the back cover of your phone and check the battery. There is a white moisture strip on the battery. If it's pink/red and not white, you have moisture damage. If you can't think of any spills, there are a few other things that could have happened. For example having it in your pocket while you were sweating heavily? Or having it in a high humidity environment like a steamy bathroom? Drop in in the snow? The only real way to get it fixed is to replace the keyboard entirely. Thankfully on the BlackBerry it's not too difficult and the keyboard isn't too expensive. If it's under any sort of warranty, take it to your carrier and they should just replace it. If not, go to eBay and purchase a BlackBerry Curve 8520 keyboard, then view the video to see how to replace the keyboard.
Can the BB receive calls ok? If not, is the sim activated and the mobile network switched to ON on the phone (GPRS/EDGE) should be displayed next to some signal bars at the top right of the screen. If they are both ok, try a battery pull, if that doesnt work try the phone in a different area to see if they get any success. Normally this messge does point to a network issue
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
sgh d880 screen is totally blank & everything is ok widout screen. everything is ok when connected to tv output, the screen is displayed on tv bt it is white on phone plz solve my problem.
