Question about Whirlpool RBS305PD Electric Single Oven
RBS305PDS16 Whirlpool oven
The power to the entire oven has gone out. Have verfied house circut breaker on and there is power to the main electrical connections inside the oven. No lights, sounds from pushing the keys. Completly dead.
This has happen twice before and the power has come back after 3 to 4 hours, except for this last time. Recomendations?
Thank you Todd
  • Anonymous Dec 25, 2008
    I had just finished using to oven and was cooking something on the stove.  I decided to use the oven timer set and went back later to find the screen completely blank.  Per user manual checked circuit breaker and it was not tripped. Thank You so much for your help.  Is replacing the board a project I can do my self?
  • norma20619 Jan 01, 2009
    oven went slowly dead replaced thecontroller board didnt fix it
  • 3 Answers
Most likely the control board has gone bad. You can find the control board here. If you have any other questions, please let me know.
Post back.
techgirl26
Posted on Sep 13, 2008
Where is the breaker to the oven is it a certain breaker that controls the oven or s it the breaker controls the house like the lights and the TV and the main things that controls the house
The breaker for the over is normally in the main house fuse panel. Be very careful when working on any electrical feed for your oven, that is normally a 240v outlet.
Dec 24, 2014 | Frigidaire Ovens
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
No power is there a reset button
There is no reset button on this model.
Check to make sure your circuit breaker is not tripped in the home.
There are internal safety thermal devises that could have tripped or the main control board gone out.
Apr 24, 2010 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Model GBS307PB00 has error codes
HI. The reason for the PF code will be the result of the power cycling. When you switch the breaker to the off position, the main control board assumes that there has been a black out, thus, triggering the PF code. This is not your principal issue here. The F3-E0, which is your main issue, is the result of a failed oven temperature sensor. The control has sensed that the actual sensor circuit is stuck open(Not functioning or energized).
Your main control board is programed to shut off the entire unit, due to this apparent failure within the oven temp sensor. The necessary actions are to have the affected part replaced, asap. I would, also, advise to preform an electrical test. I will list the entire procedure below. Follow carefully, and with caution. Make sure that your units is unplugged before administrating the testing procedure.
Sensor testing procedure:
First,you will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Apr 05, 2010 | Whirlpool GBS307PDS Electric Single Oven
I have a Whirlpool Oven RBS305PDS16 is having an error code E1 F2 and then it shuts off. What could be wrong?
E1 F2 means bad connection between touch pad and control board. if connections are ok it may require parts. may get very expensive.
Aug 20, 2009 | Whirlpool RBS305PD Electric Single Oven
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
My oven is beeping!
Try turning it off at the mains, then whilst turning it on, press and hold the cancel button.
Check the fuse and any other electrics on the same ring; eg. Washing Machine - this can indicate that the circuit breaker has tripped, replace any fuses and check integrity of electric on that circut, then flick it back on.
Jan 26, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Oven fan keeps on clicking
There are two things that you can check. one is your circuit breaker itself and the other is the internal terminal block that the main wires feed into. the terminal block could have loose wires which will cuase an intermittant PF to appear on the oven, disconnect from power before checking. The voltage at the oven will have to be checked with a multimeter to verify the proper levels. Be sure to be extra careful around electrical connections while the oven is connected to power.
Mar 06, 2007 | Whirlpool RBD245PD Electric Double Oven
Whirlpool RBS305PD Electric Single Oven Logo
262 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
