Question about GE GSS25LGM Side by Side Refrigerator
Lock on thru the door panel
The lock activates on its own and sometimes, I can't get it unlocked. Since it's a garage fridge, is there anyway I can disconnect the locking mechanism for the thru the door functions still allowing the ice and water dispenser to work? Is there a site that gives a breakdown on the wiring and how to disassemble it?
Thanks in advance.
    Scholar:
  • 111 Answers
The lock is just that. A controlock. If it is locked, the dispensor will not work. You probably need a new dispensor board since it is coming on by itself
Posted on Dec 16, 2008
Power locks keep locking and unlocking . had to disconnect battery for it to stop
you have 1 faulty door lock, fords all over the world are bad for it, they break the small activator switch, find the faulty door lock and replace it, leave your dash along
Jan 13, 2014 | 2001 Ford Explorer Sport
My isuzu trooper driver door won't unlock
If the door wouldn't close how did you close it to lock it and have to exit out the passage side door? Anyway if the door is open like you said and it's locked you can easily access the locking mechanism without removing the side panel. It's on the side of the door, not the inside and not the outside, but the thin strip visible only when you open the door. There will be two metal pieces that clasp together. You can separate them manually, this will unlock the door.
Jun 13, 2017 | Cars & Trucks
Need help with auto-locks!
When you get the doors unlocked, simply unplug the lock servos (motors) inside the door panels. The locks will still work manually and with the key. If they don't work with the key, then remove the linkage from the servo, to isolate the power lock function from the lock mechanism. Test the key while the door panels are off to avoid having to take them off twice to remove the linkage
Jun 02, 2017 | 1996 Buick Regal Olympic Gold
My panel in garage blinks on and off and I cannot open the garage door from my car
Most of the time, that means someone has accidentally activated the Remote Lock Out feature on the inside wall mounted door opener switch. Check your Owners Manual for instructions on how to deactivate this.
Feb 18, 2011 | liftmaster Garage Door 1/2 Hp
My garage door wanted open, there is not green light on the pad anymore the ele power is on
YOU MAY AVE LOCKED OUT THE REMOTES
IF THE GREEN LIGHT ON THE WALL CONTROL BLINKS PRESS THE LOCK BUTTON TO UNLOCK.
IF THERE IS NO LIGHT CHECK THE LOW VOLTAGE WIRING (A STAPLE CAN SHORT THRU THE INSULATION AND CAUSE ALL KINDS OF PROBLEMS).
HOPE THIS HELPS
Jan 22, 2011 | liftmaster Chamberlain Garage Door Opener...
Garage door only opens from button inside garage not by bour remotes in our cars ( 2 remotes )
FIRST CHECK TO SEE IF THE LOCK/VACATION BUTTON ON THE WALL CONTROL HAS BEEN ACTIVATED. THE LED ON THE WALL CONTROL WILL BE FLASHING. - SIMPLE SOLUTION PUSH THE LOCK BUTTON AND HOLD FOR 2 SECONDS TO TURN OFF LOCK FUNCTION.
SECOND TRY TO REPROGRAM THE REMOTES TO THE UNIT - THEY WILL SOMETIMES LOSE MEMORY IN AN ELECTRICAL STORM.
IF REPROGRAMMING DOESN
Nov 13, 2010 | RTO Automatic Garage Door Closer
Central Locking
When you use your remote or insert your key in the Drivers Front door all the door locks should work at the same time by the door lock motors electrically. If you have to manually unlock the door because it will not lock or unlock by the lock motor, you need a door lock motor. The drivers and passengers front door can unlocked with the key manually. The rear doors you have to pull up the latch. If no doors unlock electrically with the remote or drivers door lock, intermittantly or all the time, you will need a Central Locking Electronic Control Module. You will hear the "beep" but no door locks will fire at all. If you have odd door locks not working intermittantly you need a new door lock motor for each door lock that malfunctions. You can hear of the door locks are working electrically. Yes, they are common problem. If you can hear the door lock working but the door still doesn't unlock you need to take the door panel off and lubricate the door latch assembly and work the lock, loosening it up. This is common as well.
May 30, 2009 | 1996 Saab 900
The light on the inside control panel is flashing
you activated lock and remotes will not work. hit LOCK or VACATION button and hold for 3 seconds. light shuld stop flashing and you will be ok. I put tape over LOCK.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not open garage door but the door still works
CHECK TO SEE IF THE LED ON THE WALL CONTROL IS FLASHING.
IF IT IS THE LOCK / VACATION SWITCH HAS BEEN ACTIVATED. THIS IS USSUALLY A SMALLER BUTTON ON THE WALL CONTROL OR A SMALL SWITCH ON THE WALL CONTROL.
WHEN THIS HAS BEEN SET TO UNLOCK THE UNIT, ALL OF YOUR REMOTE FUNTIONS SHOULD WORK.
Nov 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
GE GSS25LGM Side by Side Refrigerator Logo
149 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
