I HALF CHARGED THE BATTERY FOR ABOUT 2O MINUTES, WHICH USUALLY WILL WORK. LATER THAT DAY I TRIED TO USE THE CAMERA AND IT COMES UP IN ANY MODE 'CARD LOCKED'
MANY THANKS
Comments:
May 26, 2006
- I HAVE TRIED THE MANUAL FOR TROUBLE SHOOTING BUT TO NO AVAIL THE SUGGESTION THAT HAVE COME UP TONIGHT DO NOT COVER THE PROBLEM AS THERE IS NO ERROR CODE, JUST CARD LOCKED.
-   everytime i go to menu and set up an i press memory card its says memory card protected or some **** like that and i take it out and reset it and it does the same thing-   Guest
Always try to leave the battery charging until fully charged. Batteries like to be fully charged and then fully drained, it's not 100% causing this specific problem, but it will prolong your battery life.
Certain small brands for memory cards can have compatibility problems with some cameras, including a "card locked" message, when the card isn't locked. The big brands(kingston, sandisk etc) will usually work fine and fast with all cameras. Pretec is also pretty good.
Try using another card, and see if the problem persists. And don't completely rule out the possibility that you have the card locked... ;]
While i have now solution to this problem i have some more info for those who may....i have a a620 and two SanDisk 512 SD memory cards (both with the same serial: AX0620502617D) and both the cards did the same thing...gave me a card locked message. I looked and both cards are unlocked......i have a hard time believing the fact that TWO cards from the same manufacture did that exact same thing.
I have a Canon Digital Camera IXUSi 4.0 mega pixels and everything works except I have no picture in...
(More)
I have a Canon Digital Camera IXUSi 4.0 mega pixels and everything works except I have no picture in the viewfinder. Please can you help Thank you
Every time I turn my camera on it asks me to set the time zone, area I am in, date, etc...again....
(More)
Every time I turn my camera on it asks me to set the time zone, area I am in, date, etc...again. It's causing problems when I download pictures. They're all out of order. Even when I reset the date, time, etc. it always asks me to reset it every single time I turn on my camera.
My IXUS 400 intemittently shows a Purplish unsynchronised picture on the display and it records this...
(More)
My IXUS 400 intemittently shows a Purplish unsynchronised picture on the display and it records this when taking the picture. - any suggestions please? It used to happen occasionally but now it happens most of the time.
