Question about Protron PD-DVR100 DVD Recorder
Protron pd-dvr 100 problem
MY protron dvd player when turned on runs with lines constantly and has not color to the picture. Can anyone help me with this problelm?
Does Anyone have any idea, where I can buy Board replacement parts for my PD DVR-100
Posted on Oct 15, 2008
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
Trouble with the Dvd player and TV
switch dvd to pal in the video setup
Jul 14, 2009 | Televison & Video
Picture is black and white
If you have it connected to the 'antenna input' on your TV, change the channel up or down, and then back to 3/4 as appropriate. Sometimes the signal from the machine does not match exactly what the TV is looking for, but the TV will figure it out after you change the channel up or down. The AFC (automatic frequency control) will then try to re-tune the channel.
If you have it connected using the composite, and r/w audio, then you likely have a problem inside the DVR.
tom
Feb 16, 2009 | Protron PD-DVR100 DVD Recorder
NO PICTURE ON PROTRON PORTABLE DVD PLAYER
make sure clamshell open switch is up, its a little tit that is in front of the DVD door and off to the right, it turns the screen on when the clam shell is open.
Jan 20, 2008 | Protron 7" Portable DVD Player
PROTRON - PD-007
i have Prism DVD/MP3/CD Player Model DVD-352P as well, its remote not working any more. Any suggestion to reset the remote or reset the dvd player?
Dec 09, 2007 | Televison & Video
Divided picture on Protron PD-800 DVD/CD/CD-R PLAYER
Hi Alberto,
The split screen (identical display left & right) indicates that your DVD is on Progressive Scan.
P scan refers to progressive scanning mode and is not an indication of something broken but rather is a feature. What you can do is look over your remote and check if it's got a PS or PScan button. Pressing the button should revert to the single display. If there is no such button, pls check your menu or settings and should be there somewhere. At other times, there is a small hard switch at the rear (or front) of the player itself just for this purpose.
On your concern for no color, determine the color system of the disc you're playing, the setting of your DVD player as well as the color system of your TV. They should be the same. The 3 systems are NTSC, PAl and SECAM.
Hope this be of some help/idea. Pls post back should you have other concerns.
Good luck and kind regards.
Nov 11, 2007 | Spectroniq PD-1100 DVD Player
Protron pd-007
I finally, after several months of just giving up, figured out how to get my Protron 007 DVD player to work. I hope this works for you. I have a Sanyo TV with the video controls on the front. Here are the instructions that worked for me.
1. Turn on TV
2. switch TV to video
3. Wait for "Protron" screen (Try the PSCAN button it doesn't show.)
4. Press setup and a menu will appear with 4 icons: Language, TV, a Hammer, and an Exit icon.
5. The only two icons I needed to use were TV and the Hammer.
6. TV icon: 4 choices: a) TV TYPE = choose 4.3 LB (mine was not set there); b) TV SYSTEM = NTSC; c) VIDEO = CBBS + S - video; d) DIGITAL OUT = SPDIF/RAW.
7. HAMMER icon: 4 choices: a) PARENTAL - 8; b) PASSWORD - I didn't choose one; c) ANGLE MARK: ON; d) DEFAULT: Read.
Suggestion: If that doesn't work trying playing around with the settings to see if you can get the right combination.
I hope I made your day. I know how frustrating this can be.
Jane
Oct 11, 2007 | Protron PD-007 DVD Player
PROTRON - PD-007
make sure you connected your plugs to the video you have on your tv( video1, video 2) unless you have to have it on ch 3 or 4
Jul 17, 2007 | Protron PD-800 DVD Player
The picture is in blue
Are you using an RGB cable?(red green blue) Try playing with both ends of the cable, or replacing it. If it still doesn't work you might have a problem with the RGB output on the player, try using S-video or analog video. Try using the DVD on another TV, just to make sure. Good luck, let us know what happened.
Jun 11, 2006 | Protron PD-800 DVD Player
Protron PD-DVR100 DVD Recorder Logo
158 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
