Question about Toshiba 36A60 36" TV
No picture through cable on toshiba 36a60
My brother in law was poking buttonsThe other night and the picture on the TV disappeared and only a menu bar on the bottom of the screen was visible. He continued to poke buttons until even that disappeared and there was no picture at all. The TV/Video selection menu has only video 1, video2, dvd, ant 1 and ant2 as available selections. I seem to remember that there used to be a "cable" selection at the top of the menu. Going to the setup screen to "tv/cable" selection, "cable" will not select. The television works with a dvd in the player, but will not receive a signal from the cable box.. I had the cable company send a signal to reset the cable box, so I'm pretty sure that is ok. How can I select "cable" at "tv/cable"? Is there a way to reset all settings to factory default? I have the owneers manual for the TV, but can't find anything in there to help. Anything you can suggest will be greatly appreciated.
Steve Harsh I am having the same problem. I get just snow. The screen say ant1
Program my Toshiba 36A60 36' TV to a universal remote
Programming procedure differ to different brand of remote controls; and it is no practical to type in all here by this window. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
0028,0021,0020,0025 are the common codes that sets with most of Toshiba TVs.
Dec 15, 2013 | Toshiba 36A60 36" TV
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
May 19, 2017 | Toshiba 32DF46 32" TV
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
Toshiba 36A60 does not show signal on main antenna/signal source. Antenna 1 went out first. Video 1 and video 2 seem to be slowly losing picture. There is only snow and static instead of a picture on Ant...
The tuner module is bad and would have to be replaced, the other concern is video 1 and 2 are now becoming snowy, at this point I would suggest replacing the tv set because there are two separate issues and the cost to repair in my view would not be cost effective, cheaper in the long run to buy new tv.
Jan 25, 2011 | Toshiba 36A60 36" TV
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Av and cable inputs stopped working over night
this is caused by your Hyper board failing
It is not availble anymore but try Tops Electronics in Haverhill ma or shop
Nov 24, 2009 | Toshiba 50H82 50" Rear Projection...
Same problem
sounds very much like cold solder joints
or small cracks around transformer pins and transistors on heat sinks
if you used too much windex on screen it could of disabled the remote sensor
needs some thorough checks
Sep 02, 2009 | Toshiba 36A60 36" TV
Toshiba lcd tv 17" 2003 model
I called my Brother in Law whom is an Electrician. He basically told me the same answers that your experts have told others. We're all pretty sure it's the cord, just haven't decided if it's worth it to spend 60 bucks on a new cord.
Thank you,
I'm sure We'll be back!
Jun 10, 2008 | Toshiba Televison & Video
Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Grey Screen
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
Jun 23, 2007 | Sanyo DS32224 TV
Toshiba 36A60 36" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
