Question about Kenmore Ovens
Gas stove top works, but oven does not.
I have a Kenmore Gas oven. The stove top igniters and gas work great, however the oven just stopped working a couple of days ago. There is no smell of gas when the oven is turned on like normal however, it sounds like it attempts at turning on just now gas. I cannot find a model number on this thing any where either. If you need I can send a picture of it, if it would help. Oven is at least 4-5 years old.
  • JonnyBdc Sep 14, 2008
    I mean that the gas is not working to the oven just not the stove. Just trying to find out what part I would need to solve this problem.
    President:
  • 1,952 Answers
The Kenmore 24-Inch Self-Cleaning Gas Oven 30472 features a low-maintenance self-cleaning feature and is offered at a fair price.
Many retailers offer only a limited selection of gas ovens for 24-inch cutouts, but Sears has a fairly good number of models to choose from. And the 30472 stands out because of the its price and the self-cleaning feature. Since most 24-inch models are so similar, you'll want to make finding the best price your priority.
The 30472 (Sears item 02230472000) built-in gas oven offers a feature set that is typical of ovens in this category. You'll find a modern frameless door design and a digital display. Most all products offered today have a built-in clock and digital timer, like this one. The interior light goes on automatically when the door is opened. As an alternative, you can switch on the light manually without opening the door. This allows you to take a peak at a cake or other food without any heat escaping.
As is typical, this model also offers a pre-heat signal. Unlike the ovens of yesteryear, when the selected temperature is reached, this model will alert you.
Offered here in white, this model also comes in black (30479), bisque (30474), or stainless steel with black (30473).
At an attractive price, the 30472 warrants some serious consideration because of the self-cleaning feature.
For more information:
Sears/Kenmore
3333 Beverly Rd.
Hoffman Estates, IL 60179
1-800-349-4358
www.kenmore.com
Posted on Sep 14, 2008
    Genius:
  • 1,239 Answers
Hi
On some ranges, there is an automatic shutoff valve located in the pilot assembly that shuts off the gas to the burner any time the pilot and the burner are both off. If this unit malfunctions, don't try to fix it yourself; you should call a professional service person for repair or replacement.
An electrically operated shutoff valve used on some gas ranges has two facing valves, an electromagnet, and a manually activated reset button. The thermocouple fitting is next to the pilot valve, as in most burner systems. A small amount of electricity holds the facing valves apart. If the pilot light goes out, no electricity is generated, and the valve closes to turn the gas off. On this type of system, relight the pilot by depressing the reset button and holding a match to the pilot. It should take about a minute to light this pilot. If you aren't able to relight this system, call a professional service person.
    Genius:
  • 1,665 Answers
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Gas oven not heating, stove top working
Is your stove electronic ignition? Can you here the ignitor clicking as it trys to light? If so the gas valve on the back of the stove for the oven has failed and is not letting gas to the burner. If you smell
Jul 04, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Kenmore Oven not working
Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 27, 2008 | Ovens
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
769 people viewed this question
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
