I need to get the drum out of my Hoover washer to replace the bearings.
    Genius:
  • 1,239 Answers
Hi Step 1: To remove the control panel, remove retaining screws spaced around the panel. They are usually located under a piece of molding or trim that can be pried off. On some machines, you'll have to remove the back of the control panel, also held by retaining screws, to get at the working parts of the controls. Knobs on the control panel are usually friction-fit and will pull off. Some knobs are held by small setscrews at the base of the knob. Loosen the setscrews with a screwdriver or Allen wrench and pull the knobs straight off the shafts.
Step 2: To remove the service panel, remove its retaining screws, then spread an old blanket on the floor to protect the washer's finish. Make sure the machine and hoses are drained of water. Tip the washer over on its front or side to gain access through the bottom of the machine. The bottom of the machine generally doesn't have a service panel because it is usually open.
Step 3: To remove the top of the cabinet, insert a stiff-bladed putty knife into the joint between the top and side panels and give the knife a rap with your fist. This should release the spring clips so that the top can be removed.
Posted on Sep 13, 2008
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
Replace the bearings on hoover hwb240-80
its called a bearing kit the drum has to come out
Feb 19, 2015 | Hoover Washing Machines
Hi the belt on our hoover hnl 6166 nextra will not stay on. The motor and the drum seem to be out of alignment and there are no broken screws or bolts or wobbles. Any ideas please? Thanks Robert.
I would suggest that the drum is out of alignment because the main bearings have failed, or the drum shaft has collapsed due nto corrosion.
Spin the drum by hand, and listen for any noise, there should not be any, and see if the drum rotates centrally in relation to the outer drum
Feb 02, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
TROUBLE CHANGING BEARINGS, DUE TO BEARING SHaft pushing through the bearing as we try to draw the drive end bearing off with bearing pulleys
You will have to remove the complete drum and shaft assy from the washer to change the bearing/s, there is no other way of doing it unfortunately.
Oct 12, 2010 | Hoover AL130 Front Load Washer
Very noisy Hoover VHD9143ZD washing machine - just 2 years old
yes bearing housing get loose in plastic drum. needs drum replacement.
Oct 29, 2009 | Candy Washing Machines
Buying rear drum bearing on hoover AAA140
Hi.
If you put oover in your web browser, click on laundry, you will be given different options, you will eventually get to spares and a enquiry section.
You shouold then be able to find what you require.
Jul 31, 2008 | Hoover AAA140 Front Load Washer
Hotpoint wm80 bearing replacement!!
The drum will have to be removed.
Bearing replacement on ANY Hoover can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Hoover washers require at least 2 specialized tools for removing certain components of the machine.
Jun 26, 2008 | Hotpoint Washing Machines
Dirty washing
what this could be is your bearings check if there is any amount of movement from the drum by opening the door place your palm onto the front of the washer so its on the bodypart of the washer now place your fingers into the washer facing down so you can grab the drum with them now pull up and if there is any movement then its confirmed bearings need replacing m8 get the warranty company out its a big job some companys just replace the washer m8.It will be the bearings though what those black marks are is the grease out of the bearings cause the seal has gone ive done hundreds of bearing jobs let me know how u go on m8
Jan 23, 2008 | Washing Machines
Drum Bearing Replacement
With a plastic tub (outer drum as you describe it) removal of the old bearings can deform or bruise out the plastic housing a little - you will need to check that the new bearings will be really good fit. You may need to use a retaining compound if not, to ensure that the outer journals of the bearings don't creeping round in the plastic housing and wear it looser.
I did my Hoover Electron 800 bearings (metal tub). As i recall it was fairly straightforward - needed a gasket for the tub backplate on that.
Unbolted tub backplate from tub and withdrew it through rear of chassis along with drum/drum-shaft/bearings assembly, removed pulley, tapped shaft through bearings with softfaced mallet (or hammer & wood), drifted bearings out gently, working evenly around circumference.
For plastic tub some kind of suitable extractor may reduce chances of deforming bearing housing during bearing removal, compared to drifting them out. If it'd serve to ease the new ones in too then that'd be even better.
Don't forget to check/clean the water level pressure sensor path while you're at it - stave off any problems in that area for a while while you have the machine apart. ;o)
Dec 29, 2007 | Hoover AL130 Front Load Washer
Re: rocks in machine
could well be bearings or you may have a foreign object stuck between drum and tub. if bearings, it is not an easy job and unless experienced you might be better having it done for you. recommend you get a quote first
Apr 17, 2007 | Hoover Nextra HNWF 3135 Front Load...
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
