Question about Kenwood KDC-MP235 CD Player
Lost Sirius Radio:
I got in my car today and turned on the radio. When I pushed the SRC button only Standby, USB and Tuner comes up. Before Sirius radio also was there but now it is gone! What happened and how do I get it back. I'm still paying for it and even before I bought it still use to come up trying to sell me on it... HELP Please....
  • 1 more comment
  • Markitow Sep 13, 2008
    Sirius radio is built into receiver as far as I know. On the face plate it says sirius. and from the time I took possession of the vehicle in which the radio is in. As I stated the original contract had run out and I still had Sirius come up only not as a subscruption until I payed for it.
  • Markitow Sep 14, 2008
    NO I can't get channel 184 or any channel. There is no way I can get to any channels since I can't even go to a setting for
    satellite radio. As I said before, the available settings are now only Standby, USB, and Tuner. Two days ago I had a 4th setting that said Sirius but now has disappeared. I have gone and checked the status of my account and it shows active. Thank you Mark
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is your Siruis radio built into the tuner or is it a separate device?
  • 2,794 Answers
Goto sirius.com and login to your account. Check the account status and see if its active and enabled.  If it is contact the 800 number for customer service to have the radio reactivated.
Does channel 184 work?
Posted on Sep 14, 2008
  • Tim Babcock
    Tim Babcock Sep 14, 2008
    Sound's like it's definately the radio then.  Even if your Sirius account wasn't working 184 would be active.  Best Buy can fix things like that.
Chrysler 200 convertable how to put pictures on radio
SiriusXM Connect Vehicle Tuner - Shop - SiriusXM Radio
https://shop.siriusxm.com/xm/ctl10600/cp49759/.../c...
Sirius Satellite RadioMy Account. I'm a Subscriber ... Image 1 SiriusXM Connect Vehicle Tuner · Image 2 ... Add Satellite Radio to any SiriusXM-Ready™ car stereo receiver. Connect ...
[PDF]User Guide - SiriusXM
www.siriusxm.com/.../pdf/SkyDock_UserGuide.pdf
Sirius Satellite RadioThe XM SkyDock incorporates an XM Satellite Radio Tun- er . A special .... image to match the XM SkyDock's .... found on the My Account screen (in Settings), ... Button: Tap to tag the current song and add it to your tagged song list . For.
Dec 10, 2015 | 2011 Chrysler 200
How do I display the radio ID number, so that I can listen to Satellite radio?
Verify if the radio is "Satellite ready" or if it comes with the remote tuner unit. I believe you have to buy a separate tuner add-on and antenna in order to activate the satellite circuitry - THEN it will show you a radio ID. I think ONLY the Alpine comes with the tuner. I would call Crutchfield and they can tell you what all you need with that tuner to make it work with the satellite radio.
Jan 14, 2012 | Panasonic CQ-DF783U CD Player
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Sirus radio
after the guys installed it ... u had to reset the radio... pen size reset under the volume... u have to reset it for siruis to work.. the only thing works is ch184 until u subscrbe
Apr 05, 2008 | Kenwood KDC-MP235 CD Player
Mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Oct 31, 2007 | Kenwood Sirius KDC-MP522 CD Player
KDC-MP522
Oct 07, 2007 | Kenwood Sirius KDC-MP522 CD Player
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Aug 15, 2007 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Auxillary option not available in menu
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Satellite No Longer An Option on My Kenwood KDC-MP228
Your going to need to pull off the battery cable for about 2 to 5 minutes and see if this will reset the radio. Good Luck
Mar 23, 2007 | Kenwood KDC-MP228 CD Player
Kenwood KDC-MP235 CD Player Logo
177 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
