Question about Waring WWM200PC Waffle Maker
Waring Pro Waffel iron WWM200PC
We were using our waffel iron this morning my husband went to turn the handel over to let it cook and it fell apart. Can we get replacment parts?
Thanks Dawn-di
  • Anonymous Dec 13, 2008
    The shaft between the rear post and the the grids has broken. Can this part be repaired and are there instructions on the best way to do it?
Jerseybob
  • 18 Answers
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Posted on Apr 02, 2008
SOURCE: Broken shaft
I made a template of the shaft, cut out a sturdy piece of tin to straddle the break, and then screwed that piece in at both ends after securely fitting the break together. A lot of work, but the waffle maker works great!
Posted on Dec 14, 2008
SOURCE: waring pro wmk300
Hi this is Mark again. I received the thermal fuse and installed it yesterday. The waffle iron works great. To repair the waffle maker I removed the four screws on the lower griddle and removed the round stainless cover. I next snipped off the old fuse and purchased metal wire connectors from an auto parts store. It was actually an in line wire connector (tubular) and a removed the plastic outer shell. I stripped the ends of the black wire that the fuse was connected to and crimped the thermal fuse to the black wire. To make sure it wouldn't separate I soldered the connectors. I made sure that the white silicon tube was still in place during the process and that none of the wire was exposed. If the wires touch metal you will have a short. I then reassembled and plugged it in. Volia! Back in action and waffles for breakfast. It appears on my unit that the black wire may have grounded out and that is why the fuse blew. I don't know for sure. To be safe, I will be cooking my waffles on 3 instead of 3.5. I would have to say that either you need to be fairly handy or have a friend help you and buy them a beer.
Posted on Jan 11, 2009
SOURCE: Waring pro waffle maker
There are wires that are exposed because of poor wires that seem to crack under heat or oil or both I am calling the factory now that I have opened it up and found a FIRE HAZARD inside
Posted on Apr 21, 2009
  • 4 Answers
SOURCE: Waffle Iron Sticking...HELP
I have had the same Vitantonio Model 1800 waffle maker for several years, and I've never had a sticking problem. My solution is a combination of the two above. I spray the grids with cooking spray before the first batch, but I don't need it after that because my preferred batter, which is from the Fannie Farmer Cookbook, has a lot of butter in it:
BUTTERMILK WAFFLES
2 eggs
1 cup buttermilk
½ cup melted butter (cooled)
1⅓ tablespoons sugar
⅓ teaspoon salt
½ teaspoon baking soda
1⅓ teaspoons baking powder
1 cup flour
¼ cup milk (if needed)
1. Beat eggs in large bowl with wire whisk until well blended.
2. Add buttermilk and mix well
3. Add melted butter and mix well.
4. Add sugar and salt and mix well.
5. Add baking soda and baking powder and mix until just blended in.
6. Add flour and mix until just smooth; do not over beat.
7. If batter seems rather thick, add a little milk to thin it.
8. Bake in hot waffle iron until crisp and golden (I use the highest setting on the Vitantonio 1800 and wait until the green light comes on before removing).
9. Serve with warm maple syrup and berries, if desired.
Posted on Jul 05, 2009
Sunbeam instruction manuals
Your model is discontinued.
This is the link for the latest model it may answer most of your questions for yours anyhow.
Aug 16, 2014 | Refrigerators
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
My waffle maker continues to stick even after I brush butter or oil all over the grill. I'm about ready to throw the thing away! Is there anyway to get a replacement?
Depending on how long you have had it, if you still have the receipt or not you might be able to return it to the store you got it at, espically if you got it at a target, k-mart, wal-mart ect, and switch it out for the same one, or sometimes even get your money back.
Also are u making sure your waffel iron is getting nice and hot? if its not at max temp when u poor in the batter it will stick. (most have a light on the outside that will light up, when its hot enough)
Sep 30, 2009 | Black & Decker WMB500 Belgian Waffle Maker
Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
Broken shaft
Dec 13, 2008 | Waring WWM200PC Waffle Maker
Sticking
use cooking grease before you use it other wise it will stick
Jul 12, 2008 | Waring WMK300 Professional Belgian Waffle...
WWM200PC Waffle Maker will turn on but does not heat up
Call customer service for repair. If they will not repair you can get a replacement fuse.
Jun 13, 2008 | Kitchen Appliances - Others
Waring Wafflemaker power light comes on but won't heat up
My just over 1-year old WWM200SA did the same thing while I was cooking with it (used it about 5 times). I found a solution under the WWM200PC thread that the thermal fuse blew early. I tested mine and that's what happened. It is a cheap part, but I called Waring Customer service (800-269-6640) instead and they said to send it in for replacement.
Apr 21, 2008 | Waring WMK300 Professional Belgian Waffle...
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Jan 19, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring WWM200PC Waffle Maker Logo
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
