Question about Acer AL1916B 19" LCD Monitor
Bluish screen My brother turned on the computer today and he saw a bluish screen. hit the auto configuration button and it turned back to its original state but only for a hot second. I've disconnected the monitor from the computer and I messed with the color settings but to no avail. what can I do to remedy this and mind you this computer was built for us 2 weeks ago.
  • Anonymous Mar 23, 2008
    blurish screen/resolution no higher then 800
  • nighthawk01 Jun 15, 2008
    I have nu L921G 19" LCD monitor and it's now 17 months old and it's already out of warranty. My LCD monitor became bluish screen yesterday but the windows runs normally and the programs as well. I've tried to pressed the auto configuration button but nothing happened. I've also tried to check the VGA cable but it stays the same. I changed the VGA cable with a new one but it didn't fix the problem. I also tried to connect the LCD monitor to other CPU but same thing happens(bluish screen). Please help me to resolve my problem. Please please please....
  • 215 Answers
Before spending money on a new video card you might not need. Check all your connections. I have a monitor built into a Radio station announcer's desk and it goes blue at switch on. All I did was reposition the input cable and problem solved. It was caused by a fractured wire or two in the output cable and moving it made them make contact again. It's worked for 4 years now, if it really dies then I'll have to pull it out and replace the whole cable. Check that all your inputs and outputs are firmly plugged in and any securing screws are finger tight. But remember the old tech's saying "If it's gonna go wrong it'll usually be in the first few weeks" BMW
Posted on May 27, 2006
  • 111 Answers
Not the monitor it`s video card get a new video card i hope it`s not built to the motherboard. Good luck
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
RETURN A DELL OPTIPLEX GX 60 TO ORIGINAL FACTORY STATE
maybe you have a virus or infection. Maybe you have low RAM Memory. Maybe the hard drive needs to be defragged.
You should just boot from the disk you have and that will walk you thru the install process. Put the Disk in the cd drive. Turn the computer off, then turn it back on and notice the screen for which key it says to hit to Change the Boot Order or Boot Sequence. Hit that key and let it boot from the CD start the recovery.
Apr 30, 2012 | Computers & Internet
There is a long silver button with a black moon on the upper left of my keyboard. When I accidentally hit it, the screen goes black. What is it.....and how do you get your screen back?
Depending on how your keyboard is configured, that key is set to do one of two things:
  1. Puts your computer to sleep. (A low power state where almost everything is shut off, including the monitor). You can resume from sleep by hitting any key on the keyboard, hitting the power button on your computer, or clicking the mouse.
  2. Puts your computer into hibernation. (An even lower power state where everything is actually shut off, but a copy of everything open is saved to the hard drive to be opened during start up. It basically allows you to turn off the computer, but be able to turn it back on with program exactly how you left it). You can resume from hibernation only by hitting the power button on your computer.
Hope this helps. If it does, please accept and rate the solution! You can leave a testimonial or contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | Compaq Keyboard
How to change drum to a Brother Super G3 Fax Machine instruction state to change drum, and with door open, hit the clear button until "Replace Drum?" appears, then hit 1,,,,,,well there is no...
With door open, press "Options." Screen reads, "Change Drum?" Press 1 for yes. Screen reads "Accepted." Place drum/toner in, close door. Done!
Feb 03, 2011 | Brother IntelliFax-2920 Fax
HP vs 17 screen went off center
push the auto set button on the monitors.
it has reset too. stated in the manual.
does it fail on PC #2 is no then the PC you failed on is bad.
NO PC stated
no OS stated is this XP
or the monitor is bad, as all are this old they die.
the 2nd PC test solves this in seconds work.
even an older Laptop has VGA on the rear, that can be used to do this.
Nov 16, 2017 | HP Vs17 17" LCD Flat Panel Monitor
My entire monitors display was shifted to the right (half is off screen) when I accidently pressed the auto select button instead of the off button (on the monitor) how can I get it back to where it should...
mcdevito75 here, I just hit Menu on my monitor and saw a square box with a cross in it. I fiqure this means to center the picture on the monitor, try it, or turn the monitor off, then on again and hit auto on the monitor. Hope this helps.
May 12, 2010 | HP f1905e Monitor
My monitor, some how got stuck in an odd position, and now it won't move back to its original position.
Hit menu button on the screen located three buttons left of the power button. Select Auto Adjust. The display will automatically adjust the screen to the centre. If your display is like mine, you may have to repeat these steps several, several times to correct the problem.
Apr 28, 2010 | Dell UltraSharp 2408WFP 24" LCD Monitor
Can't Connect To The Internet
Some routers such as Netgear have a reset button which can set the router back to it original configuration.
To reset Netgear routers remove the power connector from the router, use a sharp point and press the reset button, hold this button and insert the power connector, wait a few seconds and withdraw the sharp point from the reset button.
You can now configure your router to suit your ISP Internet connection.
Nov 13, 2008 | Microsoft MN-700 Wireless Router (p5308j)
Inspiron 1300 - will not completely come up
Try to boot it to last known configuration.
Hope it will work.
Oct 09, 2008 | Dell Inspiron 1300 Notebook
Acer AL1916B 19" LCD Monitor Logo
981 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
