Question about Toshiba Satellite P205-S6287 Notebook PC
Storage controller My AXI2CAI7 IDE controller has stopped working, and "update driver software" leads me nowhere.... What shall I do? Olivier
I am having trouble using the Kingston 2GB to transfer a file from my Gateway PC to my Toshiba laptop computer. Please help me.
Posted on Sep 20, 2008
My Intel RST is NOT running every time I boot up each day. Your answer didn't solve the problem. It shows in Services, it is running and on Automatic??? This just happened recently...
open control panel and select administrative tools
now select services
find intel rapid storage...
double click and open go to startup type and select automatic and click ok
Dec 05, 2014 | Microsoft Windows 7 Home Premium 64BIT...
My PC cannot see my HDD
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure connection and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 07, 2012 | Western Digital Computers & Internet
I CANT SEE MY HDD PORTABLE WHEN I INSTALL WINDOWS 7.I HAVE NO DRIVER OF SD-SIL680-RAID CONTROLER
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
http://download.cnet.com/sata-driver-intel-ver/3000-2122_4-162224.html
if this is not the right driver package
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 24, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Need help installing a controller
the drivers might be installed for this device
hope this helps
if you physically remove this sata ide card restart your computer then reinstall it this should activate the found new hardware wizard
http://download.cnet.com/windows-promise-sataii150-tx4/3000-18492_4-64684.html
Aug 06, 2011 | BYTECC PCI SATA Card with 1x e-SATA 2x...
Have an SYBA PCI IDE RAIDx2 and very urgent need the driver for Windos 7 Ultimate x64. The VIA site is out of service..!!
hi I found this link below for all syba driver updates and downloads, hope this helps.
http://it.us.syba.com/support_download/download/index.html
Feb 13, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Does the vt6421a have a driver compatible with windows 7?
According to VIA's website which just happened to be the first result on Google, the chipset has support for SATA, IDE and RAID built-in to Windows 7. So that would seem to confirm that it does, which I would imagine you've already worked out by now. Also you've probably worked out that it sucks and it's basically just software RAID except with added proprietary technology to ensure that your data becomes completely unrecoverable in the event of some hideous disaster such as using a VIA storage chipset.
Feb 11, 2011 | VIA (CX-VT6421A) (CX-VT6421A) IDE...
I have a HP m8300f Media Center Computer, and it is SATA compatable. I would like to install an older Pioneer RW DVD that is IDE. Will the CX-VT6421A do this, and what do I need to make it work? I have...
Generaly, many factors cause Blue screen and automatic restart: faulty Hardware, incompatible driver, software conflict, virus, codec issue. It is best for you to take down the dump code, and forward to mircosoft to see what they can do. What you might want to do is on your cd-dvd drive, since it uses IDE ribbons, try to see if the jumper pin is at master,slave, single on the back of your dvd rom. You should have it to single. Do you have a onboard IDE port??? If so, you can use that instead or is it connect to the harddrive, you can also set it as slave if hard drive is master. Secondly I think the Via controller you have is only for hard drive and not for optical roms, thats why it's causing a memory error crash dump.
Feb 08, 2011 | VIA (CX-VT6421A) (CX-VT6421A) IDE...
I was installing windows 7 but during installation
Follow this link and download the windows 7 upgrade advisor. Run this program and follow the instructions before installing Windows 7
Nov 07, 2009 | Computers & Internet
Mass storage controller driver
Greetings,
IDE controller starts to install the driver automatically as soon as you restart. The best way to get it completely removed from your comp is that in case you are using Windows XP or higher version goto Safe mode by tapping the F8 key on the keyboard on restart. goto control panel to Add/ remove programmes and uninstall the software completely. I hope I helped you out.
Regards,
TechSup1
May 01, 2009 | Computers & Internet
Unable to find Mass Storage Controller Driver
The mass storage controller is generally for usb devices that you've plugged in. USB keys, memory cards etc.
This kinda falls under the realm of the USB drivers for your mainboard... which if they're working, you don't need to do anything. XP service pack 2 supports USB2 just fine, but service pack 1 will require you to get your manufacturers drivers to get USB2 working at full-speed.
Why do you want to change the default driver anyway??
Aug 20, 2008 | Computers & Internet
Toshiba Satellite P205-S6287 Notebook PC Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
