Recently replaced blower wheel and blower wheel motor mounts,that problem was solved but now fan motor for the compressor runs non stop-wont shutoff except by breaker box.also changed thermostat at the same time.have i inadvertinly placed the wrong wire terminal in the wrong recepticle in either the blower motor or thermostat? If so,which one and where?How can it be fixed?The unit is a 1973 coleman evcon.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
First question first, NO! this is a simple problem and a common one to fix, just change out the outside contactor coil, the contactor has a thin layer of silver on them to prevent them from arching and sticking together, over time this thin layer burns through and stick the contactor and wont let go, till you replace the contactor coil,(20.00) 24-volt 40 voltage amp coil! YOU CAN DO THIS after you kill the power to the unit.!Thank-you-very-much!
Posted on Sep 13, 2008
2003 Toyota Corolla AC Blower/Fan will not turn on, I replaced the Blower/Fan a few weeks ago,
A/c compressor works fine and the blower motor works and shutdown right? it is the problem with the blower resistor or with blower motor relay. try to direct the resistor irrespective of the speed. hope the problem may be solved.
Jun 05, 2014 | 2003 Toyota Corolla
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
2005 envoy the fan wont shutoff after the engines been turned off
The fan for the heater right? If so, for the autoclimate control you need to replace the blower motor countrol module. If it's manual controls, replace the blower motor resistor assembly.
Mar 18, 2011 | 2005 GMC Envoy
My 1988 Ford Tempo's heater fan is not working. I can feel heat at the windshield vents,but the fan wont come on. I have jumped the fan speed switch with a paper clip--and blew a fuse--and checked the...
your circuit is simple--I will paste it below. suspect the blower has shorted and caused the switch to burn up. remove the blower and hotwire it to the battery to see if it works. If not, replace the blower. Then run continuity tests on the swoitch and replace switch if bad. If you have questions, please let me know. Here is procedure for taking blower out:
REMOVAL & INSTALLATION With Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment door and glove compartment by removing the retaining screws and bolts. Push the sides of the glove box in to free the drawer from dash panel.
  3. Loosen the instrument panel at the lower right hand of the glove compartment opening. This is on it necessary if the panel is in the way of the motor housing.
  4. Remove the retaining screws securing the ducting around the blower motor.
  5. Remove the clip securing the blower motor fan blade to the motor arm. Remove the fan blade from the motor.
  6. Remove the blower motor mounting plate from the evaporator case by unscrewing the retaining screws.
  7. Rotate the motor until the mounting plate clears the edge of the glove compartment opening and remove the motor.
  8. Remove the wire harness from the rear of the motor.
  9. Inspect the fan blade for broken edges or cracks. Replace if needed.
To install:
  1. Connect the wire harness to the rear of the blower motor.
  2. Install the motor into the case and secure with the retaining screws.
  3. Position and fasten the fan blade to the blower motor arm. Secure with the clip.
  4. Secure the blower motor outer housing to the duct assembly with the retaining screws.
  5. Install the instrument panel at the lower right hand side if removed earlier.
  6. Install the glove compartment door and glove compartment.
  7. Connect the negative battery cable.
  8. Run blower motors to make the motor works correctly.
Without Air Conditioning
  2. Remove the right ventilator assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cab
  6. Check the system for proper operation.
Oct 21, 2010 | 1988 Ford Tempo
Dryer will run and heat up but will just stop after 10 minutes. any idea what would be wrong with it.
Could be a motor going bad.
Could be a bad control thermostat.
Could be a bad auto dry sensor.
Could be lint buildup around the motor and blower wheel causing the motor to overheat and shutoff.
Try a timed dry setting and see if it runs through the cycle.
If so, the auto dry sensor is bad.
If not,Could be lint.
Unplug the machine and remove the front panel and drum to check and clean lint around the motor and blower wheel.
If all these check out OK,replace the control thermostat.
Aug 13, 2010 | General Electric DHDSR46EGWW Dryer
Replacing AC blower motor
ITS CALLED SURGERY take picture as ya go and have a big bucket for screws. make sure you have your motor and capacitor tested first before you replace it unless you know its bad (hp,sf &rpm must match !!!! on new motor ) little guys are real expensive and are a three speed motor and must be hooked up right or you will burn it UP ! do this in the shade cuz it aint no fun in the hot sun(me Florida) the first thing i would do is oil the motor then have the capacitor checked , the motor may not need to be replaced just serviced ?.. hay now if'n i was any help write a review of thanks or just VOTE,, MOTORWIZJ ..FL
May 28, 2010 | Dometic Rooftop RV Air Conditioner
Compressor and outdoor fan runs indoor fan does not. Has 230vac can't find capasitor has GE ECM motor carrier package unit 2 ton
cap usually mounted to blower housing with power off turn blower wheel if rough bad brown wires from motor should lead to cap if replacing motor get new mount belly band also and make sure rotation is correct reversable motor hope this helps
Jul 06, 2009 | Heating & Cooling
Blower motor wont start
Every air conditioner is equipped with at least two motors, the compressor and the fan motor. It is possible for the fan motor to be defective and the compressor to be running. If this is the case the unit will appear to be running and may even sound "normal" but no air is blowing out the front or back of the unit. If, after removing the cover of the unit you discover the fan blade is very stiff and difficult to rotate, the fan motor should be replaced. If the fan blade turns freely the circuit powering the fan motor will require electrical troubleshooting. It may be necessary to have a qualified technician locate the cause of the problem, which may be either a problem with the capacitor, the selector switch or the motor itself.
Jun 06, 2009 | Goodman CKL42AR42 Air Conditioner
Replace durango blower motor resistor instructions
2003 Dodge durango, the blower motor stoppped came back on and stopped again and never came back on. I replaced the blower motor and still no air. Can anyone help?
Aug 01, 2008 | 2001 Dodge Durango
Heating & Cooling Logo
143 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
