Question about Dell 5110cn Laser Printer
Dell 5110 cn
I have the same problem with our printer. we replaced everything and it still print light. did you solve the problem
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Your problem is not fully explained above as to which color you are having difficulty with, however, the explanation below will more then likely apply to your issue as well. Simply substitute "yellow" for the color you are having an issue with. This is the explanation I gave to another user who was having problems with "yellow prints lite".
If you let the yellow ( or any other color ) toner get to the point where the toner cartridge was totally empty, there is one thing you can try which may help. From the "menu", select "maintenance", then go to "clean developer" and choose the ( which ever color ran low ). The machine will then churn for a few minutes. What happens is there is a tube that moves the toner from the toner cartridge down to the developer unit ( which is behind the imaging drum). If the toner was allowed to totally run out, there is an area of the tube which may have little or no toner in it. Each time you print, there is a spring auger within the tube that draws the toner to the developer. By running the "clean Developer" it turns the auger and re primes the tube.
If this does not fix the issue, and you have replaced the imaging unit, then the (insert color ) developer is defective and would need to be replaced.
This involves quite a bit of work and is not considered user replaceable.
Posted on Oct 01, 2008
My dell 5110 is recalabrating after every sheet when I am printing duplex postcards
U HAVE 2 print the postage stamp first u dont no how to use a printer i guess. its ok.
call samprt to help you mabe? idk
Sep 12, 2016 | Dell 5110CN WORKGROUP COLOR LASER PRINTER...
How do I resolve 093-423 error?
web search dell laser printers error codes
Sep 15, 2015 | Dell 5110cn Color Laser Printer 5110 Cn
094-402 error code resolution?
web search dell laser printer error codes
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
My Dell Color Laser Printer 5110 cn won't print. It keeps saying ''Load MPF Letter'' then ''Load MPF Plain'' then ''Load MPF 020-969
it's asking for paper in the manual Paper Feeder (MPF). Somewhere in your settings you have it printing to the MPF. Check the settings in the printer prefrences, the printer itself and the software you're using.
Cheers.
Sep 23, 2009 | Dell 5100cn Laser Printer
Problems with color
There are a number of things to adjust color.
#1) reset all of the settings to default.
2) download the latest firmware and install
3) download the latest drivers and install
Once all of that is installed, there is a calibration test and setting you can do. This is all outlined in the owners manual for the printer (it is a rather long process)
The original install disk has the manual with all of the steps. If you don't have your install disks, you can download the manual from the Dell site. Just do a search on the printer, by printer make, or you can enter the service tag.
The control panel for the printer (the one you can bring up in Windows if you go to properties of the printer) has color settings and adjustments. There are also color adjustments in the printer. You can access them by entering the IP address of the printer in a web browser.
The paper you are printing on can also have an affect on the color.
Aug 26, 2008 | Dell 5110cn Laser Printer
What is the hard reset for Dell 5110cn
I have a dell 5110 cn laser printer and the transfer roller just went out.. How can I re-set this since I do not have a replacement roller. but i need ot order. Thanks
Apr 19, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Logo
1,111 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
