Samsung TXN3245FP 32" TV
Problem for Samsung TXN3245FP 32" TV
Screen green and purple in two corners
By macca on May 26, 2006
Hi ya, please help,
We've just received a gift of a Samsung 32" plano tv, second hand but looks great. We have set it up but in two diagonal corners the screen is green and a bit purple, can anyone help.
Thanks
Macca
Same Problem
May 06, 2009
-   i have the same problem in my 29' ultraslim model -   Guest
Feb 19, 2008
-   how do I remove purple and green colors from corners of tv-   Guest
Best Solution
posted on May 27, 2006
Very Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1897 votes
The chances of a damaged yolk is slim but possible. It sounds more like you've set up a new set of speakers either side of the set. Or maybe you have a VCR, CVD or setop box sitting on top of the set.
Electro magnetic fields can cause plenty of funny color problems with CRT tubes so try to kepp unshielded speakers at least 2 feet away from a TV and any other electrical appliance at least a foot.
By the way I had a TV which exhibited a beautiful color problem, it took a while but we tracked it down to the housewife turning her vacuum cleaner off right next to the TV to change power sockets and then switching the vacuum cleaner back on. Right next to a floor standing 26" TV. Her husband bought her a long extension cord :-)
BMW
Comments:
May 27, 2006
- Sorry I missed the "Just arrived bit" Don't worry, just by moving a TV over a distance can cause colour problems. The last thing a newly installed TV should have is a good degauss. If you're patient simply switching the set on over a period of a few days should fix your problem. All Color TVs have an automatic degauss coil built in and on switch on it's activated, it should remove the tints. If it doesn't then it's back to the speakers etc Above.
BMW
Was this helpful?
Yes
No
Solution #2
posted on Jun 26, 2006
Helpful)
Pravin
Rank: Wiz
Rating: 83%, 646 votes
pravin indicated that his solution for
27CX22B 27" TV Problem
is valid for all Standard Televisions
I am in agreement with the second solution. TVs, when moved from one location to another have a tendency to show color patches in the corners. A few days of usage, and the auto degaussing circuits will clear the problem. Also make sure that there are no Magnet Sources nearby (Un sheilded Speakers, some Power supply of amplifiers, A 2-in-1 music system, your kids walky-talky toy, etc.)
Pravin
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
techman
Rank: Guru  Samsung Expert
Rating: 86%, 7642 votes
your gonna need to degauss the tube with a small coil of wire. Maybe a repair shop will let you borrow or rent a degaussing coil. or try to unplug the set over night and try pluging back in in the n am and see if it took any amount of discolorazion away. if it didnt it could be the deflection yolk sahifted on the neck of the crt or the shadow mask inside the tube is damaged.. Good Luck
Was this helpful?
Yes
No
Solution #4
posted on Jan 04, 2008
Not Rated)
Raman78
Rank: Apprentice
Rating: 83%, 28 votes
Hello, i have also came across with the same problem. To solve this problem you have to purchase some small magnetic chips ( used over the back of the picture tube, if you notice the picture tube carefully, you will see some black magnetic chips pasted on the picture tube, which are used to control the color of the pic. tube) which are easily available in the market. Bring that magnetic chips and move over the back of the picture tube and where you see the color pacth gone just paste it there with tape. Do it on both the sides and the color pacth will be gone. For this you have to keep the tv on. Please be carefull while doing this, if you are not expert do not try to open the TV
Was this helpful?
Yes
No
Popular Solutions for Samsung TXN3245FP 32" TV
Questions and Unsolved Problems for Samsung TXN3245FP 32" TV
Do you recommend Samsung TXN3245FP 32" TV?
Answer
Answer
My samung series 6 turns off then on 5 seconds later have been doing it for a while tv is 1.5 years... (More)
Answer
me to have facing the same problem.i had CS21A530 purachased on september 1 st, after one day , i... (More)
Answer
our 6 year old Samsung HDTV turns off automatically. We have comcast HD service with a cable box.
Answer
Tv will be on then all of a sudden it shuts off and makes a clicking noise. Sometimes you can power... (More)
Answer
Plugged the tele in yesterday and all worked fine. Switched off and went to switch back on and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
