Question about Brother IntelliFAX 5750e Laser Fax
My brother intellifax 5750 have apaper jam and i do not know how to fix can u plz help me out
My brother faz 5750 e keeps coming up with a offline open cover I do that and it does not fix the problem HELP
Was there a paper jam or something happen just prior to the code? Was it moved bumped or dropped?
Make sure all your doors have the acuator fingers still prtruding, one may be broken and not closing the safety interlock.
Let me knw
Jan 09, 2011 | Brother IntelliFAX 5750e Laser Fax
We have a an error 38 on brother intellifax 5750 laser fax - I can't find the manuel. How do I clear it?
menu *2864 in quick succesion, should flash and say test mode, press either 091 or 91, and then try 099 or 99 to return to main screen
Jun 02, 2010 | Brother IntelliFAX 5750e Laser Fax
Where can I get a Brother Intellifax with a bad
1-800-BROTHER should get you to an authorized repair center.
Nov 06, 2009 | Brother IntelliFAX 2800 Laser Fax
MY BROTHER INTELLIFAX 1840-C SAYS UNABLE TO CLEAN HELP PLZ
I have the owner manual but it doesn't help. it only tell you so much. they want you to send the machine in. My warrenty has exspired on mine, so i'm going to trash it. I had to buy another one, wonder how long that one will last. email me and I will scan and fax some pages.
Sep 14, 2009 | Brother IntelliFAX 1840C Plain Paper...
REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
My brother intellifax 5750 has a paper jam and it wont clear.
make sure no paper is in unit then turn off and unplug for 5 minutes then plug back in and turn on
Mar 06, 2009 | Brother IntelliFAX 5750e Laser Fax
Brother IntelliFAX 5750e Laser Fax Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
