1. Press and hold the Camera key down, then tap the On button.
2. Release the Camera key when advised.
3. A black screen appears, with green writing. At this stage press the Down volume key to select Recovery Mode.
4. An icon appears, showing a triangle containing an exclamation mark above a handset.
5. Slide open the keypad then press and hold the ALT key and tap the W key.
6. The handset will restart to complete the reset.
hope this helps
John
Hi, This is a common problem but there is hope. Open the phone and turn it over so that the camera is facing you. On the
left side between the camera lens and the vol up/down buttons
squeeze that area. This is where the ribbon cable is connected.
By squeezing this area you reseat the connection. Let me
know if this helps you.
