Question about Refrigerators
Samsung fridge freezer
Hi, my freezer temperature led started blinking earlier today, when I got back tonight the whole thing had defrosted. I looked on this website and a blog mentioned the same problem and suggested turning it off for a while and then switching it back on. Although NOW the fridge AND freezer wont go below the default temperatures of 15 and 16 degrees.
Can you help?
  • dianefit Oct 15, 2008
    My freezer is not cold...ice cream has melted. The temp indicator says 4 degrees, but the refrigerator side has not temp at all.
    Sergeant:
  • 409 Answers
Sounds like the defrost thermostat is the problem. since it's located in the back of the fridge, behind the access panel, i would have a technician look at it.
Posted on Sep 13, 2008
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
We had a new Samsung RS267TDWP side-by-side frig delivered earlier today. The refrigerator side is cooling off nicely, the freezer side is not. Should we expect the freezer sideto begin cooling when the...
It takes approx. 24 hours for a freezer to reach optimal temperature and to stabilize, only because in a 24 hour period the machine will shut off about three times for it's defrost cycle, but like you listed, freezing temperature will be reached in about 6 hours.
Aug 29, 2012 | Refrigerators
I have a samsung RS2578BB side by side refrigerator. my problem is .. the fridge side is not cooling sufficienlty , even after i set the fridge temperature between 46 F and 34 F. At first, the panel...
this is a common fault, you need to replace the defrost heater and thermal cut-out in the fridge section behind the salad buckets, a temporary fix for a few weeks is to switch the whole thing off at the wall and leave the fridge and freezer doors open for at least 24hrs to allow the frozen up evaporator to defrost.
regards
Ian.
Apr 17, 2011 | Samsung RS2578BB Side by Side Refrigerator
We have a 3 way Dometic fridge in our caravan. Have lived in the van for last 12 months ( grey nomads) have had no probs until trip home this week from Yulara to Victoria. Pulled up at night and freezer...
Temperature does play a big part in the efficiency of the fridge. The condenser at the back of the fridge needs cool air flow to allow gas vapour to be converted back into a liquid.again.
Nov 12, 2009 | Dometic RM2652 Refrigerator
Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Jun 30, 2008 | Refrigerators
Blinking temperature control
You need to check the limit thermostat for the defrost in the back of the refrig section. I replace it with a standard bi-metal type from a Frigidaire to keep the problem from reoccuring.
May 16, 2008 | Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
