Question about Maytag Dishwashers
I have replaced the liquid dispenser top, but now cannot understand how to place the liquid wih the new cover so that I can get rid of the spots on my glassware. Lynn Barlow
    Genius:
  • 1,239 Answers
Hi Accumulated detergent from prior washings can cause problems with the soap dispenser. Buildup can get into the soap dispenser and interfere with the spring that triggers the flip-out tray, or it can slow down the pivot action of the tray. If the dispenser is not opening, first make sure you aren't loading the machine so dishes or pots and pans are touching the dispenser, and that dish racks aren't blocking the dispenser. Also check to make sure the dispenser tray isn't cracked. If leftover detergent in the tray is almost liquid, rather than just damp, the tray may be damaged.
If you can't solve the problem easily, replace the entire dispenser unit. This is usually easier than trying to disassemble it and replace separate parts. Use a new dispenser made for the dishwasher. The screws holding the dispenser in place may be on the front of the unit, or you may have to remove the front door panel to get to the screws and make the replacement. Remove the old dispenser and secure the new one, connecting it in the same way the old unit was attached.
Posted on Sep 13, 2008
  • Maytag Master
  • 19,396 Answers
If you post here your model number, I can find the exploded view for the dispenser and the manual.
Alternatively, If you post here your model number here you get the diagram yourself.
Thanks.
    Brigadier General:
  • 5,158 Answers
Make and model of the dishwasher. and some details... does the door open differently to the old door. it is very possible to put the door on in reverse.
Robert
    Genius:
  • 3,422 Answers
Can you please give the make and model no. of your dishwasher?
Bleach left in washing machine dispenser
Remove and clean the drawer of the dispenser
Mar 28, 2014 | Kenmore Oasis HE 27082 Top Load Washer
How to fill with liquid to keep glasses from spotting
open door look on the inside if you have a knob beside your detergent door un screw it like a soda cap counter clockwise. Pull out fill hole with liquid jet dry. screw cap back into place clockwise. just snug, not too tight. your cup should be full and dishes spotless. However not all have the jet dry dispensers so you may have to buy the dry variety that hangs in plastic basket on your rack.
If dishes still have spots you may have a water problem that may require a sevice technicians assistance for you.
Mar 03, 2011 | Whirlpool Dishwashers
How do you put the liquid soap dispenser back
The "bottle" screws in from the bottom. The "pump" is inserted in the top. I usually fill mine from the top without taking out the bottle. Too much of a pain. Just make sure the large nut holding the hardware in place is secure before you start assembling the bottom and top. If it's loose, the whole thing will wiggle around. Good luck!
May 07, 2010 | American Standard Contemporary Kitchen...
Soap in wrong dispenser
Just do one or washes with an old towel in the drum. Keep doing these washes until the m/c no longer froths.
Oct 04, 2009 | Kenmore 42822 Front Load Washer
Where to put the detergent and liquod softener in newHaier washer
Detergent goes in the drum with the clothing, fabric softener in the middle of the agitator, the drawer is for delayed start if using soap powder
Apr 04, 2017 | Haier XQJ50-31 Top Load Washer
Spots on clothes
Chris your agitator problem is repairable. remove the fab softener cup and the cap on the agitator down inside the opening you should see 4 pieces that look lik a tear drop is my best description for them your are wore out and do not engage when the agitator agitates replace them and you'll be good as new.
Mar 19, 2009 | Roper RAS8445KQ Top Load Washer
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Fridgidaire front loader washer/ problems with softner dispensor
In the back of the dispenser is a button / lever to press down to remove the entire dispenser. Remove it and take off the cover over the fabric softener / bleach chambers. You may find some junk under the cups in that cover, or in the tubes sticking up through the bottom of the dispenser.
The way this thing works is like this: You fill up the dispenser with the liquid, but that liquid doesn't get up to the top of the tubes. When it's time to dispense, the washer adds water to the appropriate chamber, raising the level to above the tube. The liquid then goes down the tube, creating a suction which (ideally) draws the rest of the liquid up into the cup, over the edge of the tube, and down the dispenser. The washer will add water several times to accomplish this. The system isn't perfect, but it usually works with few moving parts.
If the fabric softener is especially thick, it will have a hard time getting siphoned down through the tube. If it looks as thick after the wash as it did before the wash, the machine isn't adding the water to the cup. I believe on the Frigidaire, there's a separate valve (all part of the same valve assembly) for each dispenser chamber. If it isn't adding the water, you'll have to replace the whole valve assembly.
Mar 12, 2008 | Washing Machines
Hoover Floormate SpinScrub won't dispense cleaning liquid
I had the same problem and was preparing to take it back, the last thing I tried was to 'reseat' the handle -- I removed it then snapped it very firmly back into place. That did it, it's working beautifully now!
Nov 25, 2006 | Hoover H3030 FloorMate SpinScrub 500...
Dishwashers Logo
95 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
