Imac intel based 10.5 or 10.4 not sure(reason)just bought from person he could not get to boot. i have imac new 10.5run fine. heres what happen to the second imac. he said her was going to erase the hard drive went to the progam where you can erase, instead he thinks her migfht have erased but he did check permissions and then clicked on RAID now the imac wont start up. i have tryed everything i can find in mac for dummies and another mac book with white cover. i can get to the language screen and a pop up says"can not install this software on this computer" thats with 10.5 with 10.4.5 i can only get to a folder with a question mark. these computers look the same gray metal with black trimmed screen
Bittu_8
  • 23 Answers
SOURCE: Erasing hard drive
Dear Comfused,
What u have to do is take a bootable windowsXP CD boot u r system with that CD it will automatically boot the system with that CD if the system not booting with that CD then u have to go in BIOS
now go to the boot option then select 1st boot device CD drive. save it and exit from BIOS now it will restart the system no it will boot from CD then follow the instruction shown in the screen and format the C drive then it will install the fresh windows XP. Now u r hard disk get erase and u also get the fresh Operating System I hope this information will going to Help u out.
Regards,
Bittu_8
Posted on Feb 14, 2008
ginko
  • 19396 Answers
SOURCE: imac problem starting up
Reinstall Mac Os X, this should fix the problem.
Do a backup of all your files before reinstalling the OS.
If you do not know how to reinstall Mac OS get it safely done at any Mac shop, it is not an expensive operation.
Posted on Sep 13, 2008
  • 38 Answers
SOURCE: Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Posted on Nov 18, 2008
Matampong
  • 153 Answers
SOURCE: Windows is booting to recovery partition How do I stop it?
Check your CD-rom for any Installation CD in there, normarlly you go to bios to set which drive to boot from,. Ok when restart, press delete to go into bios. choose boot from HDD.
Posted on Nov 19, 2008
SOURCE: erase and reformat to be compatible with new mac
Think I might have solved it myself. Here's how:
Open Disk Utilities and select the external hard drive. Select the "Erase" tab. Hit "Erase" at the bottom right.
That's all. Just dragged a folder onto it and it worked.
Posted on Jan 12, 2009
I can't install epson r380 on new intel iMac
you will need to go to epson site try here Epson Stylus Photo R380 Ink Jet Printer at the drop down window next to Operating System: pick you operatind system then download
Apr 23, 2014 | Epson Stylus Office Equipment & Supplies
Locks frequently and restarts sometimes all by itself. Parts of the screen regularly skews in triangular shapes.
  • Verify that the power outlet you're using is good and your power cable is firmly connected to the wall outlet-if using a surge protector, be sure that it's firmly plugged into the wall outlet. Also, try temporarily plugging directly into the wall outlet to eliminate any issue with the surge protector; plug a different electronic device into the same wall socket to make sure the socket works, and also try the iMac's power cable in a different wall outlet.
  • Make sure the computer's power cable is firmly connected to the computer.
  • If any external devices are connected to your iMac, disconnect them and try to turn the computer on again. If the iMac will power up when those devices are removed, but not when they are connected, contact the manufacturer of those devices for assistance.
  • Try resetting the iMac's SMC
  • Remove and reinstall the SO-DIMM memory modules, located in the bottom of the computer.
  • Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
    1. Shut down the computer.
    2. Unplug the computer's power cord.
    3. Press and hold the power button for 5 seconds.
    4. Release the power button.
    5. Attach the computers power cable.
    6. Press the power button to turn on the computer.
Nov 12, 2010 | Apple 2.16GHz iMac Intel Core 2 Duo...
I have Apple iMac G5 + G5 iSight and i want to boot it from my windows xp bootable CD please tell me how to do that????.........
you will need an intel mac to use a xp boot disc.
or with virtual pc installed you can run windows 2000, not sure about xp though.
Sep 09, 2009 | Apple iMac G5 Desktop
Will Virtual PC for mac v7 work with an new iMac (Mac OS X, Version 10.5.7)?
Basically, if your new iMac has the new Intel processor (or any Intel based processor Macs) your Virtual PC v7 will not work on it. It is designed for iMacs/Macs that are not Intel Based machines (that run on the Motorola processors like the G3, G4 lines, etc).
All Intel based iMacs/Macs are capable of running Windows using a Dual boot startup that is available at the Mac Store or online. Check the Apple website for instructions, they are always updating the software. :)
Jul 19, 2009 | Microsoft Virtual PC 7 with Windows XP...
Spitting DVDs out?
Every company has quality control issues, Remember apple only has less than 10 percent of the market and they are exploding due to the IPOD and ITUNES so they are scrambling to keep up. Of course that not our problem its thiers but they are trying. Just for reference I have a Mac Plus in my garage which can still get on the internet. Quality has been there staple and if they didnt out source so much to keep up with demand I am sure those things wouldnt happen nearly as much.
Jul 14, 2009 | Apple 2.16GHz iMac Intel Core 2 Duo...
IMac Intel wont boot
It sounds like you need a new motherboard.
May 06, 2009 | Apple iMac G5 Desktop
Intel High Definition Audio:Device ID: 0x106B00A0
Sound is controlled in the Systems Preferences. Go to the Apple icon (top left on top menu bar), then Systems Preferences > Sound. Check the Input Output configurations, making sure that mute is off and volume is on appropriately. I would think the "Built In" choices would be appropriate. I hope this helps.
Aug 04, 2008 | Apple 2.16GHz iMac Intel Core 2 Duo...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
