Question about Medion md40298 Notebook
Vista I cannot open anz programs from the desktop. % got a window saying the Works program files were not available and that perhaps they were not installed properly.
Compatability issue
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
NOTE: If you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Regards.
Jul 09, 2010 | Broderbund American Greetings Creatacard...
Tip
How to install or run older programs on Windows 7
Since the release of Windows 7 many of my clients have been asking me about program compatibility and which programs will run on Microsoft's new operating system.
Their concerns were mainly because of Vista not running very well and they thought that they may be in for some of the same type of compatibility problems that Vista had.
Before Windows 7 was released to the public Microsoft said in a statement that "Any program that works on Windows Vista will certainly work on Windows 7"
Microsoft has certainly delivered their promise and much, much more!!!
I tested both the beta and the RC (release candidate) editions of Windows 7. In October of this year I was so impressed with Windows 7 I went out and bought Windows 7 Ultimate.
I was glad i did because Windows 7 is being welcomed with very open arms, people are upgrading so i need to know my may around the operating system.
At first i was weary about programs not installing because of compatibility problems but the procedure to either install a program or get it running when installed is relatively simple and is the same way that Vista uses.
NOTE: Again, if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Sometimes you will get a message that says "This program may not have installed correctly, Reinstall using recommended settings and This program installed correctly"
It's up to you what you do from here, if the program works choose the latter. If your not too sure click on Reinstall using recommended settings"
So far (and i keep my fingers crossed) i have absolutely no problem in getting a program installed and running on Window 7. I will however provide more tips as and when they surface.
Please be aware that not all programs will work on Windows 7. These are programs which are mainly pre-XP like programs designed for Windows 2000, Windows 98/95.
on Dec 01, 2009 | Computers & Internet
Scanning to PDF format.
I know that the Brother MFC-7840W came with a program called PaperPort, which will allow you to scan 1 or more documents into a PDF file. Perhaps your scanner supplied the same program.
Apr 19, 2010 | Microsoft Windows Vista Home Premium with...
Downloadable drivers for VN4100pc handheld that works on 32 bit
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows 7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
Mar 10, 2010 | Olympus VN-4100PC Digital Voice Recorder
.gho recover file
Have you tried a system restore?
Jul 01, 2009 | Microsoft Windows Vista Home Premium...
Problem with Compaq Fortran & Vista
I found the solution fortunately:
It's enough to do a right click on the bottom: "Developer Studio" instead of double click, and select: "Run as Administrator" , then select: "Allow" and so on..
Try it, it works!
Aug 06, 2008 | Compaq Visual Fortran Professional Edition...
After I installed Easy Media Creator 10 a "HP Cue Status has stopped working" popup window comes up on my screean and says it well close the program and will close and I will be notify when a...
This means this program not compatible with Vista.
You need to uninstall the program, and reboot the system.
Now there is a way to install with XP compatibility, 80% of the time this will work. (if this does not work, you will just have to find the version of the program that works with Vista)
To install with XP compatibility:
Running the Vista Program Compatibility Wizard 1) Click on Start
2) Click on Control Panel
3) Click on Programs
4) Click on Use an older program with this version of Windows.
5) Then just follow the instructions in the Wizard.
Insert the installation disc for the program. Open the Compatibility Wizard. In the Wizard, browse to the program's setup file (Setup.exe, Install.exe, etc.)
Aug 05, 2008 | Computers & Internet
When I try to open a pdf file, the icon is different and does not open in Adobe, but in MS Word 2007, which of course is does not open properly. This computer (Gateway M6752 laptop)has Vista Home Premium,...
Hey mrbickham,
In some instances, updating existing software or installing new programs onto your computer can cause issues such as what you have encountered. Fortunately, re-associating .PDF files with Adobe Acrobat Reader instead of MS Word 2007 may be all that you need to do. Most versions of Windows allow users to select the program they want to use to open any given file type, and can usually be done by following the steps I’ve provided below.
1) Right-click on the .PDF file icon.
2) Choose "Open With" from the menu that appears.
3) When you highlight the “Open With” option a submenu should appear. Click on the link in this menu that says “Choose Program.”
4) Another window should then open, providing a list of the available programs on your computer. Choose Adobe Acrobat Reader from the menu and check the box next to it.
5) At the bottom of the page there should also be an option that says something similar to "Always use this program to open this file type." Make sure that this option is enabled.
6) Click "OK."
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 23, 2008 | Computers & Internet
Belkin F5D7132: cannot open exe program
Windows Vista; belkin says it's compatible. install program downloads, but desktop shortcut does not appear. When I attempt to open the file, I get error message "IP802MR MFC application has stopped working." IP802MR is the name of that file.
Jun 17, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
I have windows Vista and loaded the newest Adobe Reader, but my computer will not open .pdf files that are sent attached to an email. I have uninstalled Reader and reinstalled it twice, to no avail. Any...
Do you get a dialog box saying that the file can't be opened? and down the bottom is a button with which you can select a program to open the file with?
If yes, click on this - Acrobat may not be listed (hence the problem). There should be a Browse button, click on this an work youur way to C:\Programs\Adobe\Acrobat (or some such naming) enter the Acrobat folder and find the Acrobat EXE file - click on this and say yes to all the prompts on your way out. This will now associate Acrobat with PDF files.
Hope this works.
Apr 23, 2008 | Computers & Internet
Medion md40298 Notebook Logo
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
