Question about Kitchen Ranges
I have a Diplomat built under double oven of which the large oven door has come off when I tried to clean it. Could you tell me how to fix it back again.
    Sergeant:
  • 409 Answers
Has it come off the hinges completely?
Posted on Sep 13, 2008
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
LG double oven shows f9 code in both ovens
Nov 19, 2013 | LG LWD3081ST Electric Double Oven
F9 code after cleaning
F9 means
problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, probably a problem with the lock mechanism.
A common problem on many built-in ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean
Oct 24, 2013 | LG LWD3081ST Electric Double Oven
F9 error code
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen it is clean.
F9 error code
F9 problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
Sep 07, 2013 | LG LWD3081ST Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
Buying accessories for diplomat range oven
Fixya does not sell parts and is unable to identify sources.
Jul 15, 2017 | Kitchen Ranges
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Viking Professional Double Oven
turn your selector switch to clean and then turn your thermostat to clean. the unit will latch the door and clean for a few hours until the unit cools off and the door latch opens. remove all your shelving before doing this. if you like a manual go to vikingrange.com and download your use and care for free
Nov 09, 2008 | Viking 24 in. Professional Series VUD141...
Kitchen Ranges Logo
136 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
