Question about Magic Chef Refrigerators
Fridge is not cooling or freezing
My 13 year old magic chef refrigirator is not freezing or cooling. However; the motor is running continuously.
    Sergeant:
  • 409 Answers
Can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Posted on Sep 13, 2008
What could be the problem with my Magic Chef mini fridge model number MCBR465S. It comes on when I plug it in but not cool at all, and the compressor hot, could I trouble shoot and how,freon? Thx
If the compressor is actually running and there is no refrigeration, I would suggest it has a gas leak and that's why it isn't cooling. Depending on what type of refrigerant is in it, it may not be worth repairing as its only a small bar fridge? Check the rating plate to see if its R12 (Older fridges) or R134A . If the unit is less than 5 years old, it may be operating on R32 or R600 (Butane refrigerant gases) If its only a couple of years old, it may still be under Manufacturer warranty. Most fridges carry a 2 year warranty on everything and up to 5 years parts warranty on what is known as the "Sealed system"
Apr 19, 2015 | Magic Chef Refrigerators
The motor on my frostfree fridge never stops running. Below the freezer isnt cooling. The freezer is cold but not freezing
Hi, seen this a few times when i did apartment maintenance,the most likely cause is a bad thermostat.
Mar 06, 2011 | Magic Chef CTB1722 Top Freezer...
THE FREEZER WORKS BUT THE FRIDGE PART DOESN'T. IT'S THE SMALLEST SIZE 2 DOOR FROST FREE MAGIC CHEF FRIDGE. ABOUT A YEAR AND A HALF OLD. WHAT SHOULD I DO?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 16, 2010 | Magic Chef Refrigerators
Magic Chef MCBR445W1 seems like it dosen,t stop
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef Fridge not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
709oy
Jul 07, 2010 | Magic Chef CTB1722 Top Freezer...
Re: Magic Chef
If the compressor is running but the fridge is not cooling, the gas may have leaked out of the system or the compressor is inefficient. The only way to know for sure is to connect a set of gauges to the system. You will need to call in a Refrigeration Mechanic.
Nov 03, 2007 | Magic Chef MCBR440 Compact Refrigerator
Not a themostat. 3 most common causes are defrost problem (frost on back freezer panel), bad evaporator fan motor, or damper.
Sep 24, 2007 | KitchenAid KSRS25ILSS Side by Side...
Refrigerators Logo
445 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
