Jwin JCCD200 CD Player
Problem for Jwin JCCD200 CD Player
CD do not eject
By donic on May 26, 2006
Everything works but when I press to eject the cd it does not want to eject it does not even stop the cd also the open button on the top right corner does not work ither. I try to open it and check but I did not smell anything burn is there a way to test it internally and check if it is making contact with the circuitry...
Same Problem
Feb 17, 2009
-   My cd got stuck for the second time and wont  come out . it still plays a little . I neeed it out what do I do ? What is the code to use i lost the manual for it .-   norris100
Nov 11, 2008
-   When I go to eject my CD out of my player it will make all most a ticking noise for about 20 seconds and then says CHECK CD. The CD will still play and work as if nothing is wrong but the CD will just not eject out of the player. -   Guest
Jul 28, 2008
-   I have a Jensen CD3010X installed in my Deck Boat.
When I press the CD eject button nothing happens.
The CD will not stop playing or eject.
If I turn the main boat battery switch off and back on the CD will eject my itself.-   winwren
Jul 06, 2008
-   MY UNIT IS INSTALLED IN AN OUYDOOR BBQ ISLAND. IT IS IN A SEALED CASE.
THE CD PLAYER DOES NOT PLAY AND I CAN'T "EJECT" THE CD. I TRIED THE SOLUTIONS IN THE BOOKLET (PRESSING THE SRC AND ON/OFF BUTTON AND THE SRC / SELECT BUTTON). NOTHING WORKS. THEN IT SAID TO CLEAN THE CONTACTS,NOTHING. THEN LEAVE THE UNIT ON BECAUSE IT MAY HAVE MOISTURE BUILD UP. STILL NOTHING.......CAN ANYONE HELP. IT IS STILL UNDER WARRENTY UNTIL 8/28.-   Guest
Jun 09, 2008
-   c.d. plays fine, but when I push the eject button the unit turns off, and the CD doesn't eject -   Guest
Best Solution
posted on May 15, 2007
Very Helpful)
goatboy
Rank: Apprentice
Rating: 100%, 3 votes
Use a paperclip and press the reset button beneath the Volume knob. It reset the system and I pressed eject button again, and presto.
It does reset the presets, but worked for me.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 26, 2006
Very Helpful)
Rizzo
Rank: Apprentice
Rating: 97%, 16 votes
I have the same prob with mine right now and thats why I came here was to find the manual.
In the manual it states that that when something like this happens you need to hold two buttons for a few seconds and what it does is it resets the cpu in the deck.
I had to do it before and yes I was kind of leary of the solution also but IT WORKED!!
Now I'll have to dig before posting this otherwise I didnt just create a common solution I talked about it.
Ok while holding power/ATT press eject for more than two seconds,
and it says careful not to drop the cd~~~DAAA
Or to reset the unit: While holding SEL (select) press power/ATT
for more than two seconds and that will reset the unit to factory
defaults.
And this was actually from my owners manual of which I found...
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Nov 16, 2006
Helpful)
NuuSkool
Rank: Apprentice
Rating: 86%, 3 votes
Disconnecting the Battery works the best.
Was this helpful?
Yes
No
Solution #4
posted on May 31, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3622 votes
Disconnect the car battery for a few miunutes, then see if it ejects when reconnected.
If the device is jammed, you have most likely a mechanical problem, like a bad belt, or you the mechansim needs to have the loader retimed.
Good luck
Was this helpful?
Yes
No
Solution #5
posted on Oct 20, 2009
Not Rated)
dhwhite1
Rank: Apprentice
Rating: 0%, 0 votes
The cd will not eject and the player said that there is no disc in the player. I know there is a cd in the player but the system does not recognize one. How do I get the cd out of the player.
Was this helpful?
Yes
No
Solution #6
posted on Sep 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Have a 2005 Volvo S40.....
Put the keys in and turn the power to the car on (not starting it) then disconnected the neg battery cable and hooked it back up after 5 seconds. Spit the CD right out.
Solution #7
posted on Apr 30, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Detach the face, and press the reset button.
Solution #8
posted on Mar 25, 2007
Not Rated)
Tab231
Rank: Apprentice
Rating: 0%, 0 votes
well something similar happened to me once after turning off my car I pressed eject and the cd came right out. My open button also stopped working when I press it the cd player turns off then back on I don't know about this one yet but I think I might just have to get a new cd player. Hope this helped.
Was this helpful?
Yes
No
Solution #9
posted on Jan 09, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Push and hold down bothe the SOURCE & S (Sel) buttons. Please and Eject will appear alternately on the display. See page 2 of the instuction manual !
Popular Solutions for Jwin JCCD200 CD Player
Questions and Unsolved Problems for Jwin JCCD200 CD Player
Do you recommend Jwin JCCD200 CD Player?
Answer
Answer
need wiring diagram for tview 6588ts dvd player
Answer
remote car start relays click 3 seconds and the starter engages but wont start starts fine with... (More)
Answer
i have a 1999 mitsubishi eclipse,i change my batery and my radio is asking for a code
Answer
trying to figure out how to adjust the high and low pass filters
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 29, 2008
CD plays but does not eject. The stop button does not work either nor any of the channel buttons.
Comment by Guest, posted on May 09, 2008
when i press eject the cd does not eject
Comment by Guest, posted on Apr 20, 2008
Don't have owners manual (bought a used vehicle with this unit already installed). Can't figure out how to eject a CD.
Comment by jack081, posted on Dec 31, 2007
My cd was stuck in the player. I took the player apart and removed the cd, however, the system will not take any new cd into the player. What is wrong????
Comment by Guest, posted on Dec 29, 2007
I have a JVC KD-SX949 and there is a CD stuck in there. The display says that there is no disc in there. When I push the eject button, it won't eject since it thinks there is no CD. I have tried to reach in with the end of a pen cap and push in the CD a bit more to make sure that it was in all the way, and that didn't change anything. The radio and everything else works fine, and the ejection button isn't jammed-it opens up the player, but no CD comes out. What should I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
