Question about Samsung WEP500 Wireless Headset
Not Charging I left it charging one night and the next day i wasn't seeing the charge light on the cradle.....I tested the cradle and adapter with a multimeter and it checked out. I'm in jamaica...so my options are SERIOUSLY limited where repair is concerned....any trouble shooting tips or does it sound purely technical?
  • Anonymous Mar 24, 2009
    I tried that, still didn't work. Didn't even see the light blink once
Same thing happened to me the other day. For some unknown reason my wep500 seemed to just die with no apparent cause or reason. So I took the unit apart and tested the battery with a multi meter. It read 3.9V. So power was not the issue, I then put it back together and by chance, happened to continue pressing the power button for 5 seconds in hope I would see the LEDs flash but no dice. Then for no reason, I went to my phone and tried to pair and to my amazement it actually paired (meaning the device must of been on). So I then hit the big button on the wep500 and sure enough it calls the last number stored in my phone. It turns out (out of all things) the led itself went bad for some unknown reason. I suggest you try charging it (you won't see the red led), try turning it on (you won't see the blue led) and then try pairing from your phone. If you phone indicates it paired, then try calling the last number from your wep500. If it works, then you too have a bad LED (I have never seen an LED go bad before). Hope this helps.
Posted on Mar 30, 2010
I faced the same problem too. Sometimes the connection is bad. If the light blinks/ is unsteady, then it could be a connection problem. So try gently pressing the cradle (the power cord back side and front side where the red/blue light appears) together. If that's the issue you should see the red (charging) light on continuously.
Hope this helps!
Posted on Nov 04, 2008
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
My refurbished hp compaq mini wont charge I havent yanked the cord or anything. i have had the computer for not even a week. it charged fine for the first few days but one night i left it charging and the...
It sounds like you have a bad battery charger, but it could also be slightly corroded battery contacts. Make sure the contacts on the battery and inside the computer are clean (you can use a qtip and alcohol, or a pencil eraser). You will have to measure or have someone measure the output of the charger, to make sure it's putting out a good charging voltage. You can use a voltmeter to do that.
If you can run it by Best Buy, they can check to see if the charger is good. There's also a possibility that the battery has gone bad, and in that case, they may not hold a charge.
Good luck, and hope this helps.
Mar 24, 2011 | HP Mini 1000 Netbook
Good afternoon, I´m trying to
Have you tried:
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
I was searching for this today and happened to find the above on the plantronics website. It definitely frustrated me till I found out about how to put the base in pairing mode.
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Problem of charging the battery
Check battery indicator. If OK, update BIOS. If no change, check battery bios info, if AC Adapter is incorrect, replaces it. Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jul 12, 2010 | Dell Inspiron 1525 Notebook
Won't turn on
The device may just be locked up and needs to be reset so that it can start up normally. To do a reset on the device, make sure the unit is plugged in to the charging cable/cradle and connected to power. Next press and hold the Mode + Reset buttons at the same time for approximately 10 seconds. After releasing the Mode + Reset buttons, attempt to power the device on normally.
Dec 18, 2009 | Garmin Forerunner 305 GPS Receiver
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Does not hold a charge. I have tried charging it for 2 days and when I unplug it and check the battery it says zero charge and shuts off!
if you see the amber light on the charging cradle then your battery no longer holds a charge. if you don't see the amber light then your pda is not charging when in the cradle. most likely it's a battery problem. good luck.
Jul 16, 2009 | HP iPAQ RZ1710 Pocket PC
Battery charging
i have not used my camera since June, when i went to charge the battery the other night the Red light just kept flashing even after leaving it for 8 hours, i can get pictures from it which are stored in it but the shutter will not open whilist in and out of the cradle.
May 28, 2008 | Casio Exilim EX-S880 Digital Camera
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Samsung WEP500 Wireless Headset Logo
729 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
