Question about Philips Magnavox 51MP392H Rear Projection Television
Help! Please I have a 51mp392h/17 chassis mag1 aa no pic only sound, in a previous post you said you had a link to buy the bad board. Could you send me that link please? Thanks, Tim
  • Philips Master
  • 8,617 Answers
Heres the link your needing the DPTV large signal board.
http://servicemanuals.vstore.ca/
Posted on Sep 13, 2008
Philips Magnavox Rear Projection 51mp392h color adjustment
Hello, below in my post is a link to the Manual library. there are detailed instructions on how to adjust the color. it takes time and some steps are difficult but using two people you should have no problem just print them out and go step by step... also I suggest doing it at night with low lights or off, and let the TV warm up for 20 mins.
Good luck, below is my general post with lots of info
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox
Need more info, does it click on and off, make any noises, was the picture going blurry, did you just move it, was in built into a wall where it wouldn't get air to cool???
Here is what I know about the 51mp392h this is a general post below I used for some other peoples fixes without more info on yours I suggest reading thru the below and links and add more info to your post so we can trouble shoot it.
51MP392H/17
What you need:
Red and green lines on picture only in the corners of the pic
YIKES, I dont know about Coolant changes but I'll post my general post about the 51MP392H/17
it has links to the SERVICE MANUALS and info to other sites that might help...
GOOD luck
General post....
51MP392H/17
What you need:
Nov 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
Have a philips magnavox 8p6044 c102
Hmmm... I dont know where to find those CTR Circuit boards I'll post my general post for you about what I know it has links to the manual and some other sites it may help.
how bad is it burned, did some chips go or just the copper circuit board tracers. you can use circuit board wire and solder it from point to point,
I had somewhat of the same problem with my IC board, I had a bad portion of the board where I had to build a new copper routing with circuit wire, the copper burned off when the resistor failed, you may need to do a little Frankenstein work on your board as a last resort... remember use a low 15 watt soldering pencil, use leaded solder, and USE flux!
however with all my work, I got it running but the IC board is still not running perfect. if you decide you cant fix the TV I would love to buy your IC convergence board from you.
GOOD LUCK! hope I helped...
GENERAL POST WITH LINKS BELOW.....
51MP392H/17
What you need:
Nov 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
No Picture No Sound Magnavox Rear Projection Television
51MP392H/17
What you need:
Nov 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips rear projection tv-wont turn on
Sounds like your Convergence chips failed, were your red/blue/green colors slowly seperating or was the picture starting to curve on the top or bottom or both? if so see below general post.
Also what model # is your TV and what size?
51MP392H/17
What you need:
Nov 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Audio only, no picture
Audio without video is usally a vertical or horizontal deflection problem with the DPTV chassis and Mag 1 chassis which is what you have. You may need a new deflection Large signal board. If you would like a link to one of those boards let me know.
Jul 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
51mp392h/17 model number magnavox
try resoldering the vertical output IC. That may be the problem bad solder has been known to cause that symptom in the chassis
Mar 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
No sound no pic!
That is the DPTV310 chassis I believe the problem could be in the power supply input board or the large signal board. I have a source to locate those boards used if you would like me to post it. They sell parts cheap and all parts are in good working order. I have used their parts many times.
Feb 23, 2008 | Philips 55PP9352 55" Projection Television
Tv has soun but no picture
51MP392H/17
Where I got my parts that worked:
What you need:
chips
Nov 05, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
109 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
