Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Audio but no picture
I have a Mitsubishi WS-55315 the audio is present; however, there is no pictue. How do I begin to fix this problem?
  • Mitsubishi Master
  • 19,396 Answers
Try first unplugging the tv for one hour,
you can also try also a whack test, tapping gently the TV on the side , if you get picture then it is a wiring or a bad connection.
If you have no picture it can be the lamp, if the lamp is fine is either an internal board or the light engine, but this is uncommon.
here you can buy replacements.
If you need a technician call the number listed on the owner manual.
Posted on Sep 13, 2008
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi WS-55315 parental lock is on.and i have no original remote is there a fix
You are going to have to have a Mitsubishi remote to do it--with that contact Mitsubishi and ask for the 4 digit code to enter to do the hard reset of the set--puts everything back to factory original when set was new.
Mar 14, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Protector glass on a mitsubishi 55in hdtv 1080 #ws-55315
I have the same tv and I took my clear shield off and never put it back on.  The picture is much better without it as it will reflect light and objects in the room making it difficult to see the pic clearly.  I was told by a service tech that the primary purpose of the glass or shield is to prevent damage to the screen from objects, water etc.  If you have no small children in the home you can enjoy a better pic.
Dec 26, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 no video present
Appreciate the direct "Ask Me".
You description of "...no video but with audio..." could indicate a number of possibilities:
  • power supply section;
  • tuner
  • video amplifier/selector;
  • vertical section;
  • horizontal section .
Other ideas are:
  • Since it has still sound, then the power supply is a least likely possibility;
  • Since it has still sound, then the tuner is a secondary suspect;
  • Since the menu shows, then the vertical and horizontal would be highly unlikely.
  • which eaves us the video amplifier or electronic/soft selector as the most likely culprit.
Further diagnosis would of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 audio no picture
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Sep 14, 2008 | Mitsubishi WS-55315 55" Rear Projection...
sound is one circuit ... picture is over 3 thousand. I havent a clue either.
try turning it off and on fast... if see a flash or white flash you have high voltage at least as high voltage collaspes. check your inputs on remote you might be on av 2 or something.
Sep 13, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
No Picture Audio Only
It sound like the components are ok. Are any of the component leads discolored from excessive heat? If so it may be that the resolder looks ok but is not actually adhering to the lead. Use solder wick or a desolder iron to remove the old solder, clean the lead(s) by scraping with a sharp knife edge to bare good metal and resolder.
Dec 08, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
