Home | Kyocera | Finecam S3L Digital Camera | Power
Kyocera Finecam S3L Digital Camera
Problem for Kyocera Finecam S3L Digital Camera
Power
By kosyl on May 26, 2006
When I turn My camera on, it turns off. It doesn't stay on. I tried buying a New battery and charger and it's still the same problem..HELP! Please
Comments:
May 29, 2006
- I had my camera fixed. The problem was that the contact wasn't getting enough power from the battery causing it to turn on and off.
Thanks for the help.
Same Problem
Apr 15, 2008
-   My Vivitar 3315 turns on and then 2 seconds later it turns off on it own.-   Guest
Feb 20, 2008
-   When we open the camera the lens is still blank please give me advice-   Guest
Feb 10, 2008
-   When I turn my pwer switch on, the camera immediatly turns off. I have put new batteries in and same problem.-   rbrushpa
Dec 05, 2007
-   i have a Kyocera Finecam S3L Digital Camera. The adaptor shows green ligth indicating that the cam has been charged only 10 min after the charging has begun. Moreover evn keepin the power on after that the cam doesnt take more than 2 or 3 pics even after charging for the entire night. need a suitable soluntion. thnx-   bajajdivya
Best Solution
posted on May 26, 2006
Helpful)
dovi
Rank: Guru
Rating: 88%, 2492 votes
To my regret,it seems like a problem with the lens servo motor.The lens unit can become damaged if it's opened while it was in your pocket, or in its case. The power button gets pressed and the lens attempts to extend, the lens gets jammed and the servo motors is damaged.
This problem should be repaired by a certified technician.
Ask first for repair cost quotation.
Good luck !
Was this helpful?
Yes
No
Solution #2
posted on May 27, 2006
Somewhat Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1891 votes
It's a major problem for all cameras which have lenses popping in and out. Quite often dust can be sucked in and jam the drive up. Sand from the beach is the worse problem. The most common fault is the camera has been dropped lens down from just about any height. If you're not handy it may be cheaper to sell it on Ebay as faulty and buy a new one.
If you are handy or daring :-) you can often clear the problem by removing the lens assembly and using compressed air on it to blow any grit out of the way. To dismantle the actual assembly can be really asking for trouble as they can be mongrels to put back together. But if you're methodical and have a good memory you may be lucky.
WARNING don't do what a neighbout did and squirt WD40 into the camera lens. In fact avoid any lubricants near cameras.
Was this helpful?
Yes
No
Solution #3
posted on Jan 24, 2008
Not Rated)
Zarek
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem, I used a plastic ball pen without the cap to twist the inner battery contacts up a bit and voilá!...it works!
Thank you kosyl!!!, you are my hero!!!
Was this helpful?
Yes
No
Popular Solutions for Kyocera Finecam S3L Digital
Questions and Unsolved Problems for Kyocera Finecam S3L Digital
Do you recommend Kyocera Finecam S3L Digital Camera?
Answer
Answer
Can I charge my Kyocera Finecam S3L using the DCin connection on the side of the camera? I bought... (More)
Answer
I have a Kyocera Finecam S5R and it does't make any photo. It was working very good an suddenly I... (More)
Answer
Hello all, After comming across this site whilst searching google i'd thought i'd post a problem i... (More)
Answer
Dear Sir,, For four month now I am trying to find an agency in Canada to fix my Kyocera finecam S3L... (More)
Answer
on turning camera on, says card cannot be used. have 4 cards all same. one pin in card slot seems to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kyocera Finecam S3L Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
