SOURCE: I'm installing a new rear tail light with turn
use a light pen that you can get from auto parts store to find the hot wires for l and r sides
SOURCE: How do I remove the back tire on a 2008 Yamaha
CHECK THIS LINK http://www.venturerider.org/wheel/
SOURCE: how difficult is it to revove the back tire on a
This is a surprisingly simple job, even easier if you have a lift. Remove the saddlebag on the right (throttle or rear brake pedal) side of the bike.I recommend doing it now because the bike is more stable on the sidestand; you will have to exercise considerable caution once it's on a lift, or the rear tire is otherwise elevated. There are two different length screws (three shorter, one long), a spacer, a variety of stand-offs, and a variety of rubber isolators and washers. Remove the parts (two mounts in the floor, two in the back toward the frame) but KEEP TRACK of where the parts come from, and in what order you remove them. (You're gonna hear this a lot, but replacing a part lost or misplaced prior to reassembly, or having to dismantle and reassemble the bike because things don't fit right is a LOT more aggravating).
The rear caliper and brake disk are now exposed. Remove the two hex head bolts holding the caliper to the caliper arm, lift the caliper off the disk, and gently lay the caliper outside the arm. If you've already changed the hoses to the stainless-steel reinforced type, you needn't be too careful; if you're using the hoses the bike came with, take exceptional care not to nick or cut the hose. Examine the axle on that side of the bike, CAREFULLY AND COMPLETELY noting the location of spacers and washers; when it's reassembled, you'll have to duplicate what you're looking at right now.
Prior to lifting the bike, loosen (but do not remove) the self-locking nut on the opposite side of the wheel (on the outside of the final drive unit) and the pinch nut at the end of the swingarm on the caliper side. Now, lift the bike, making sure the rear wheel is suspended and unobstructed to both the right and rear. Remove the nut from the side of the final drive and extract the axle shaft. It doesn't want to move? You're left with two choices - grasp the end of the axle shaft outside the swingarm with a pair of Channelocks or some other toothed, clamping device, and twist until it loosens and comes out - OR - remove the other saddlebag and use a 3/8 extension or extensions to tap the axleshaft through. I do not recommend the Channelocks - the scoring of the axleshaft is permanent and UGLY; if you think it looks bad after the shaft is out, wait until the RUST sets in...
With the axleshaft out, the wheel is probably hanging askew between the swingarm and the final drive unit, and there's an assortment of spacers and washers lying on the ground. Move the loose bits out of harms' way, GENTLY move the wheel toward the swingarm, and it should drop to the ground, and roll out beneath the fender. BE CAREFUL NOT TO LET DEBRIS GET ONTO THE EXPOSED DRIVE SPLINE ON THE FINAL DRIVE, THE MATING SPLINES IN THE WHEEL, OR INTO THE BEARINGS. Those areas are really, really, really difficult to adequately clean after they've been contaminated.
Reassemble in the reverse order, torque specifications for the axle nut - 110 ft.-lbs. (150 nm), for the pinch nut on the swing arm - 17 ft.-lbs (23 nm). Bolts for the caliper should be torqued to 30 ft.-lbs. (40 nm).
It's a good idea to lubricate the drive splines in the rear wheel and the mating shaft in the final drive while the rear wheel is out.
SOURCE: how do i charge battery
First, I should explain the difference between most motorcycle batteries and the car batteries that people are more familiar with.
A car battery is usually a "lead-acid" battery, a design largely unchanged, except for the composition of the lead plates, since the turn of the century. The battery is composed of alternating plates of lead and lead dioxide in an acid bath. Adding plates increases the electrical capacity, dividing groups of plates into "cells" increases the voltage available. It's a very basic battery that has worked in stationary and vehicular applications for centuries.
A motorcycle battery is usually an Absorbed Glass Mat (AGM) battery, differing from the car battery in only one respect; the space between the plates is filled by a porous, fiberglass-like material that has been saturated by acid. The advantage of the AGM battery is that it is less susceptible to damage from the increased vibration experienced in a motorcycle or high-performance car.
New motorcycle owners are frequently tempted to use the same battery charger they're accustomed to hooking up to the family sedan, but this can, and usually does, cause premature failure of the battery. Because the motorcycle battery is smaller, it requires less current to charge it, and the excess current generates heat. Because the acid does not circulate between the plates of the battery and distribute the heat and gas generated during charging, the battery heats much more rapidly than the car battery. Heat interferes with the chemical processes the battery performs during the charging cycle, and may cause plates to bend, buckle or crack.
Now, you've probably seen "battery tenders" advertised in motorcycle magazines, at Radio Shack, in Walmart and Sears. This is what you should be using - look for a MAXIMUM charge rate of 2 amperes/hour (it's typically described as "amps"), and a reduced "trickle" charge rate (usually automatic) of 1/4 to 1/2 "amp".
To get to the battery, look under the operator's seat (either side) 1"-2" behind the back of the fuel tank; you'll see a nut holding a threaded shaft into tabs protruding from the frame. Loosen and remove the nuts on both sides, lift the seat up until the threaded shafts are completely free of the tabs, then move the seat straight forward. That will free a catch, molded into the underside of the seat, from a loop in the frame that holds the back of the seat down and keeps the seat from moving side-to-side. The seat may then moved out of the way.
Now you will see the battery in the frame; hook the red lead of the battery tender to the battery terminal with a red insulated boot over it, and hook the black lead of the tender to the opposite battery terminal. The battery tender may be left connected for days, weeks or months at a time, but unless the bike is well protected from the weather, it should probably be disconnected after 16-24 hours and the seat reinstalled.
Reinstallation of the seat is the in reverse order of its' removal (above): there is a specification for the nuts - 5 ft.-lbs. (7 nm) - but it's usually sufficient to tighten the nuts snugly on both sides.
