Question about Magic Chef CAV2000 Top Load Washer
Magic Chef W225LV
The cold water runs constantly whether the machine is on or off and no matter the cycle.
    Problem Solver:
  • 5 Answers
Solenoid is causing it
Posted on Jan 03, 2009
Magic chef du4000v
You can install it on the cold water line. The dishwasher has its own heating element to heat the water.
Apr 06, 2014 | Magic Chef Dishwashers
The washer does not stopping rinse cycle.
are you saying there is no water or it keeps filling
if no water change the cold water valve
Feb 04, 2014 | Magic Chef Washing Machines
My washer,a W225LV will work one day and not the next! When it quits you can smell something .....wait a while and it starts to work again! It was bad out of balance, what is wrong!
THE MOTOR WOULD BE MY BEST GUESS WITH OUT LOOKING AT IT BUT IF IT WILL RUN A BIT THEN CUT OFF AND A SMELL IS COMING OUT OF IT THEN CHANCES ARE THE MOTOR IS OVER HEATING AND CUTTING OUT ON OVER LOAD PROTECTION
Nov 02, 2010 | Magic Chef CAV2000 Top Load Washer
W225LV water flows and drains constantly. Tub won't fill up
HI, this is a siphoning issue.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Sep 20, 2009 | Magic Chef CAV2000 Top Load Washer
Tub does not spin but agitates
Sounds like the door switch is either loose or faulty. The door switch keeps the tub from spinning with door/lid open.
Charlie
Aug 21, 2009 | Washing Machines
Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Jul 23, 2009 | Magic Chef CAV2000 Top Load Washer
Washer will not operate in cold water
sounds like the water inlet valve solenoid is burnt out on the cold side, hot side is ok. if you have the machine set for a cold water rinse, and the solenoid is burnt out it is calling for cold water and it will not come into the machine. change the water valve.
Mar 02, 2009 | Magic Chef CAV2000AWW Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
We have a magic chef washer that is letting the cold water run in constantly, even with the power off. also, it will not spin out now. model# cav2000aww. serial# 14430432ae.
Your valve( inlet valve ) is broken or stuck due to residu
You have 2 water valves. Most likely it is the one directly where the hose connects.
Follow LINK for drawing and Parts
Jun 14, 2008 | Maytag Washing Machines
Magic Chef CAV2000 Top Load Washer Logo
152 people viewed this question
Top Magic Chef Washing Machines Experts
Robert Smith
Robert Smith
Craig Hill
shaun taylor
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
