Question about iLO V27DMBX Television
Nothing happening bought new ilo 27inch, watched a dvd on it and towards the end the tv lost picture but kept the sound and was frozen no buttons worked. i unplugged the unit and reset the tv according to manual and it worked for five mins. then the pic fizzeledut and then the same.well the tv has not rebooted since. the display lights show that the tv is in pc mode or pc energy save mode-is this fixable?
  • 1,476 Answers
It certainly sounds like something which would be repairable. It would also seem from what you have said that the unit is still under warranty and should be repaired for free by the manufacturer. Check with the place you purchased it or the manufacturer. Good luck.
Posted on Jul 06, 2006
No picture no sound just a whistling noise
maybe the flyback transformer or horizontal output ic
Jun 01, 2009 | RCA 27R411T 27" TV
Sound but no picture on TV
Try hooking your components up to the "AV1" and "AV2" jacks on the TV. I experienced this when hooking up my DVD and VCR (movies of my kids so kept it around). I hooked one to AV1 jacks and one to COMPONENT jacks and had the same result you're describing. Hope this helps.
Mar 28, 2009 | Philips Televison & Video
Tried connecting DVD player to ILO 27 in, no go
go to video on your remote, then go to composite... it should work on composite mode. Took us a while, don't feel bad. Hope that works for you.
Nov 14, 2008 | iLO 3200 32 in. LCD Television
My ilo tv wont work wright
I do have the same problem on my ILO 26HD It worked fine for about a year and sudenly it got freezed, can anyone please find what it is?? Thanks!!
Aug 14, 2008 | iLO 2600 Television
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Dvd burner
Can you try just running a/v cable from your tv output to the inputs on the ilo, then whatever you watch on your tv you can record on your dvd burner. My new SDTV doesnt have audio out except Coax so this won't work for me on that tv. Why doesnt the newer tv's have audio AND video outputs???
Oct 30, 2007 | iLO DVD Recorder DVDR05
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
32 in ILO tv, goes blank
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
Apr 27, 2007 | iLO 3200 32 in. LCD Television
iLO V27DMBX Television Logo
54 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
