Question about RCA RP5420 Clock Radio
RCA 5430A - some display elements don't illuminate
Had my 5430 dual-alarm model about 7 months. For past two months, one by one, some of the LED elements of the numbers have stopped illuminating. (It's a challenge to figure out what time it is!) Also, for BOTH alarms the "radio alarm" indicator does not light up anymore. Seems like every couple days a different LED goes dead.
  • JoeAir Sep 15, 2008
    Same as mentioned before. I purchased this unit from walmart. Don't know if this is a cheaper version of their products.
SOURCE: Emerson Smartset alarm clock
I found the manual on this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
Just click on your model number.
Posted on Aug 10, 2008
SOURCE: RCA RP3721 Alarm won't shut off
To turn alarm off completely, press WAKE1 and WAKE2 until the bell-shaped indicators go off.
As for resetting the alarm (buzzer), press SET WAKE/CLOCK untill SET and WAKE! light.  Press left- or right+ arrow to set time.  Press WAKE1 until bell-shaped indicator comes on.
Posted on Oct 24, 2008
SOURCE: need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Posted on Nov 05, 2008
blueextc3221
  • 15935 Answers
SOURCE: Good Morning. I was given
Following are the instructions for the RP5610 which looks very similar to the 4801A (that I also have). The only difference in the instructions is that the 4801A doesn't have a clock icon, just press the SET button until the center colon dots are flashing, Press the rewind or fast forward arrows on the circle next to it to set the time. Set the alarms by pressing the set button until bell 1 or 2 is displayed. Nap is also set with the set button - not sure how to stop it yet.
To set the clock:
  1. Press the SET button until the clock icon is displayed (circle with hands at 10 and 2)
  2. Press |<< REV or >>| FWD to set the time.
  3. AM or PM icon will show besides the time.
Posted on Dec 24, 2008
SOURCE: Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Posted on Aug 05, 2009
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
My Element 32 inch tv has black screened.
hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
Sep 09, 2012 | Televison & Video
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
My K9 alarm is silent. I am not hearing the noise when I open the doors are close them. How can I activate this feature again?
Is the LED indicator illuminated steady (not flashing)? If it is, than the system is in valet mode. In order the turn off valet mode, you need to press and release the valet button once. The LED should turn off and you will be able to operate the security system.
Jan 23, 2011 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
I have a diplomat fan oven. I repalced the fan element about six months ago. everything worked fine, however in the past couple of weeks the motor has been running slowly and erratically. now something has...
Sounds like the fan motor has failed altogether, and as a result the oven element has probably blown again due to overheating of the element.A ew fan and element is more than likely going to be needed to correct the problem.
Dec 16, 2010 | Ovens
How do I Set Time on a RCA 5430 A Alarm Clock
follow the below link..., I was able to find a pdf. on the fixya website.
http://157.254.235.130/public/RP5430_ib.pdf
Oct 08, 2010 | RCA Radio Alarm Clock
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Quorum Elert
Hang on...I might have a line on the manual. I'll post when I get it.
Dec 16, 2007 | Computers & Internet
RCA RP5420 Clock Radio Logo
81 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
