Question about Sony SDM-HS73 17" Flat Panel LCD Monitor
I was given a Sony SDM-HS73 and it seems to have a horizontal hold issue?
I saw a post when looking at the one of the sections on Sony SDM-HS73 monitors, but was a bit confussed. First there are 4 sections referring to the model Sony SDM-HS73. Then on one of them I found a little hope. It says for "Stretched Image" (picture stretched from top to bottom) to go inside and find the horizontal adjustment, but I was inside checking all the plugs and connectors inside for tightness and did not see anything that I thought would be the horizontal, or vertical for that matter, controls. This is a flat panel LCD monitor. Can you tell me if there are really such controls and what to look for?
  • 3 Answers
SOURCE: Black screen after 1/2 second power-up of Sony SDM-HS73
bratty, do you have a pic on which capacitor this is? Also where I can find a replacement one.
My monitor is doing the same thing, nice and bright for 1/2 a sec then goes super dull, you can barley see anything.
Thanks,
Jake
Posted on Dec 18, 2007
SOURCE: Sony SDM-HS73 Not Staying On
The problem is with power inverter, usually the capacitors go bad and need to changed, they might be bulged and or leaking. Very cheap fix, less than a buck apiece and an hour with a solder iron. Google it to find more info.
Posted on Feb 20, 2008
stabelabel
  • 51 Answers
SOURCE: my sony sdm-hs73 has white lines on the display
The display Has been damaged you have lost some of you input will problem need a video broad replacement.
Good Luck
Keep me posted.
Posted on Mar 16, 2009
landsend
  • 1066 Answers
SOURCE: Screen saying out of range?
change the resolution settings in the computer control panel until one works.
Posted on Apr 03, 2009
preachw996
  • 1179 Answers
SOURCE: Display orientation issue
Right click the mouse on an open area of the desktop, In XP select properties; Vista it's personalize. Go to the display settings and make sure it is set to portrait. Hope this helps.
Posted on Jul 02, 2009
What is bulb length for this sony sdm-hs73 17inch monitor?
Please read here: http://lcdparts.net/howto/selectccfl.aspx
It is where I get my replacement lamps from.
I hope you do have real steady hands.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/#!cpZZ1QQtppZZ20
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 27, 2011 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Sony sdm-hs73p LCD blacks out
Common problem in the HS73/93 is bad soldering works in the lamp assemblies, see my pictures here:
But look for bad caps (leaking/bulging top) first in the power supply section.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 01, 2010 | Sony SDM-HS73P 17" LCD Monitor
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Hello!Sony SDM-HS73 power-inverter problem
At this point you may have bad transformers, bad tuning cap, you need to check the frequency of the inverter oscillator to see if both of them are running at the same frequency, the bad one may not be. The Inverter/power supply is not made by SONY, Powernet makes the board. Please see what went wrong with the one I fixed.
One thing to keep in mind, when the board turn into carbon (blacken), it will conduct. The circuits operate at high voltage and high frequency.
Apr 09, 2010 | Sony SDM-HS73/H (Grey) Monitor
Jul 02, 2009 | Sony SDM-HS73P 17" LCD Monitor
My sony sdm-hs73 has white lines on the display
Good Luck
Keep me posted.
Mar 16, 2009 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Sony SDM-HS73 problem
there may some spike(voltage goes above 1000v for few microsecond) come from electricity board
which may damaged colors ic you have to replace it and connect spike arrester before pc
Oct 29, 2008 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Sony SDM-HS73 17" Flat Panel LCD Monitor Logo
56 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
