Question about RCA F27242GY 27" TV
Vertical collapse Horizontal line through center, all else black. Audio good.
  • 53 Answers
Please give model # it will be on back of set will start with ctc-atc or itc
Posted on Jun 15, 2006
  • bill mckee
    bill mckee Jun 15, 2006
    my bad i meant chassis # not mod #
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
No picture, Horizontal line center of screen
Can be a case of vertical collapse. If this is the case, then the vertical oscillator and/or the vertical driver circuit are faulty. .
You can take you problem directly to zenith. They have a customer service post available here
Mar 30, 2008 | Zenith Z32H41D TV
Tv has horizontal line in middle of screen,sanyo ds25390
hi if only a horizontal line across with no video anymore, you have bad either vertical ic or no dc supply b+( vertical ic ) or no output dc coming from the ic. if it is not totally a horizontal white line and you can see a video you must check leak or bulged capacitors at the vertical section near the vertical ic. hope this can help good luck.
Oct 02, 2012 | Televison & Video
Black screen with bright horizontal line through center
Your vertical IC may need resolder. You may have a bad capacitor or two that created an extra warm IC and create bad grounds. So resolder and check those caps near and around your vertical IC. If you continue to see this horizontal line you may have to replace the vertical IC. And you may as well check all grounds as well. Good Luck and be careful!
Jun 18, 2010 | Broksonic TV
Stationary horizontal lines
This is a flyback issue and it would need to be replaced. Aslo check the horizontal IC's for faults.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Philips CCA132AT 13 in. Combo
Bright horizontal line across black tv screen
Hi There,
If your picture has collapsed to just a horizontal line across the center of the screen, this indicates that your Vertical Output circuit is bad and needs to be serviced by a qualified technician. I hope this helps and thank you for using FixYa!
Mar 29, 2009 | JVC Televison & Video
Green horizontal line in center of screen.
Bad vertical output ic. Also, check resistors and diodes around vertical output ic.
Mar 23, 2009 | Sony KP-46V35 TV
Picture screen
Hello! You have vertical collapse. There are bad solder connections at the vertical output IC. I have repaired MANY panasonic tv's like this. Very easy to repair if you have any soldering experience. If soldering does not fix the problem you need to replace the vertical IC. Good luck
barneyluc
Oct 06, 2008 | Televison & Video
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
RCA F27242GY 27" TV Logo
100 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
