Question about Dryers
Kenmore clothes dryer model number 110.86880800: drum turns but no heat
  • brumar0 Sep 16, 2008
    Thankyou to both zeusfaber and abishek33. The problem definitely was the thermal cut-out as well as the thermostat. Apparently Sears either believes, or knows these two generally go out together, as they package both parts together. As I already had purchased the thermostat due to one of its tabs coming off when I disconnected the female connection, I knew that part was bad, and sad to say did not complete looking for bad parts.
    I also checked the heater element, and it came through with flying colors, as did one other thermostat and the timer.
    It works!
    Thanks again, you saved me time and money.
    Bruce
  • 247 Answers
My instinct on this one is to look for a thermal cutout and to try to reset it.
Not familiar with the layout of the Kenmore 110's (they're not marketed in this part of the world), but a good place to start is probably inside the top of the machine.
Before fiddling, turn the power off and unplug the machine.
Look for a metal duct leading into the drum housing. This will probably have the blower mounted at one end, then the element embedded in it, then, before it leads into the drum housing, a collection of thermostats and safety cutouts (usually one or two of each) mounted on the outside of it.
Safety cutouts and thermostats are likely to look something like one of the pictures at http://www.tdspares.co.uk/products.asp?cat=68
Start by looking for cutouts with reset buttons - press the button on any you find and see if this fixes the problem. It's a good sign you've found the right one if it clicks when pressed.
If that doesn't work, use a multimeter to test across the contacts of each thermostat and cutout in turn. They should all have a very low resistance. reset or replace any that don't.
Once you've got the machine working again, you need to find out what made things trip and eliminate the underlying problem. This is usually a matter of cleaning all the accumulated lint out the machine.
Good luck.
A.
Posted on Sep 13, 2008
    Genius:
  • 1,239 Answers
Hi Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.e the heater:
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.
Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Drum gap
what is the model number?
Dec 09, 2012 | Kenmore 83142 Electric Dryer
10 year old kenmore model 110 gas dryer drum turns but will not dry clothes
I have a Kenmore Model 110.74612200 it came with the house and needs another service call-not heating- how old is this model? Wondering if it might be time to buy a new one. Dryer has seen a lot of use in the past 5 years from a household of six.
Feb 21, 2010 | Kenmore 63942 Dryer
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
I get black streaks like the rest of you.. I
it's not the drum,it's the felt pieces that the drum rides on, there is felt on the back of drum and theres a felt piece on the front bulkhead, they could be worn leaving a space letting the clothing slip through hitting the black rollers or something is falling through the space hitting the clothes next time send the model number so i can look up your dryer,the model number is around the opening where you put the clothes into the dryer,open the door and look around the opening and you'll see a tag with model and serial number
Jan 22, 2010 | Kenmore 73952 Gas Dryer
Kenmore Gas Dryer Model # 97281800 - will not turn on. The dryer will not turn on, does this machine have a Fuse?
kenmore 97281800 drum turns good ,all vents are clear,only blows
very little.take the cover off blower compartment blows a lot.only warms the cloths. runs very well just does not dry. WHY does the blower not blow very much when its all together? is that the reason the heat cycles mostly off? three hours to dry a well wrung out load
KEN
Dec 23, 2009 | Kenmore Dryers
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Clothes dryer doesn't spin
The way most domestic clothes dryers are made, it's usually hard to determine that the heating part works without the drum turning.
But, chances are, the drum belt is broken.
Please give the specific model number of your unit for a more complete response.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Stuck clothes
There are durm glides that support the front part # 5303937139
you can look up and order at www.apdepot.com
Hope this helps
Jul 18, 2008 | Kenmore 62722 Electric Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
