Question about Sony CLIE PEG-SJ30 Handheld
HOW TO TURN THS THING ON
HELP
Hello Battery has to have a Charge and at the very top next to the pen there is a button it that button and it turns on only if you have any battery, if not it will not turn on.
Posted on Jan 18, 2009
  • airhed692000 Jan 18, 2009
    sorry typing to fast. "there is a button it that button" I forgot the "H" in HiT.
My car keeps makn a tickin noise when i turn leftd but had cvs done please help what ths might be
That could be your leftside axle..the boot pn the axle could be broken and.all the grease came out.
Jan 20, 2013 | Honda Cars & Trucks
When i turn on stereo the amp goes into power protect
Kevin Lasserre,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 27, 2011 | Dual Car Audio & Video
Tourqe on rocker arms for a 3.0 push rod motor
Its not realy a torque its a clerance in ths of an inch the intake are 14 ths to 16 ths real tight and the exhust valves are 15 ths loose to 17 ths real tight I have a 2.9 so your will be close likely the same but it needs to be done in sequence the cam shaht has to be just atarting to push up on the valve stem to make this adjustment its usely the firing order that needs to be followed its called valve lash adjustment and you should check for the 3.O JUST TO MAKE SURE ITS THE SAME AS THE 2.9
Jan 17, 2011 | Ford Taurus Cars & Trucks
Help!
sound like the display board might be dead
Feb 28, 2010 | Washing Machines
1991 S-10 Blazer... Would not shut off in Park! Cannot get the key to turn it off. Help
Review the Neutral Saftey Position sensor, sometimes ths is the problem, the car dont start or dont cut off when the NSP sensor need adjust.
Nov 05, 2009 | 1991 Chevrolet S-10 Blazer
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
I cant get my sansa mp3 playr 2 turn on?
i had this problem today-though mine sounds a little different. i need more info to correctly answer this, but i'll give it my best shot. when i tuned my Sansa on, it said 'battery too low. system shutdown' so i charge it same thing. here's what i did.
1)carefully unscrew the back off
2)you should see a big white thing with all ths Japanese kanji and what not on it. this is the battery.
3)what i did was i took out the battery since it is customer replacable and i put it back in. the same one. it works now.
~loli~
Dec 13, 2008 | SanDisk Sansa e250 MP3 Player
I have an LG LMVH1750ST microwave convection oven. When I activate the fan for cooking purposes and then try to turn off, it does not respond. I have to pull electrical plug and reprogram for one minute....
From the owner's manual under OPERATION "VENT FAN":
"If the temperature from the range or cooktop below the oven gets too hot, the vent fan in the vent hood will automatically turn on at the 4-Speed setting to protect the oven. When this occurs, the VENT ON/OFF pad will not turn the fan off."
You should check your "vent fan auto time set" setting.
Here's one thing to try to set it to turn off after 10 minutes:
Touch the Vent ON/OFF pad, then touch the "5-SPEED VENT" pad until "level 4" appears in the display, then touch "AUTO TIME SET" the desired number of times.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | LG Microwave Ovens
Need operating instructions for Royal DM4070
i had same problem. put new batteries in and then pressed the reset button on back of organizer and it came on immediately.
Mar 17, 2008 | Royal DM4070
Tally T2280 THS ERORR 001
I have been told that this is a Printhead, or Logic Board fault.
Git rid of it on customers by cleaning printhead(two screws then taking printhead out & cleaning connections, Replacing).
But now i have THS error 009 ??
Dec 11, 2007 | Tally Matrix T2280 Printer
Sony CLIE PEG-SJ30 Handheld Logo
88 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
