Question about Husqvarna Viking 1
Needle locked in right position
The needle is locked in the machine's right position,cannot get it to move to center.Tried the zig zag stitch and it just makes a very very narrow stitch.
  • mtnpleasure Sep 13, 2008
    I don't see where I can remove the needle holder.I don't want to stitch a zig zag stitch,was just trying to see if I could get the needle position to go to center.Needle does not change position when I tred the zig zag or other stitches that would require the needle to move back and forth.
    I have no idea what you are talking about.
    Let me try one more time.The machine makes only straight stitches with needle not in center position.Will not make any other stitches,zig zag,blanket,overcast,blind hem, or other programable stitches.Is it possible it is te circuit board?
    Sergeant:
  • 241 Answers
What is the model number and brand name please.
If this is a newer model you may have the progam/function
set on the wrong pattern
My wife uses a newer style with all this cool features on it but
it took a while to figure it out.
The needle may not be postioned correctly and also
check the shape (bent) or see if the arm lookes bent
the part that holds the needle.  Just turn it on and watch how it looks
if it is normal up and down and it is not lose or bent you may just need to
adjust it
Thank you
Jasyon
Posted on Sep 13, 2008
  • 4 more comments
  • Jayson Brollini
    Jayson Brollini Sep 13, 2008
    Is your modle the emerald or the Platinum 955 E series
  • Jayson Brollini
    I just need the model
    thank you
  • Jayson Brollini
    your machine if it newer has 2 or 4 small screws holding the needle on.
    You need the tool to loosing them (hex wrench or alan wrench)
  • Jayson Brollini
    here is the best way that I can help you ok
    go to this link and you will need to also check
    your software for updates.
    www.husqvarnaviking.com/us/9181.htm
  • Jayson Brollini
    Sorry this will take you there the link is safe and the correct URL
  • Jayson Brollini
    Designer I Updates since 1998
    • One touch basting around an embroidery design.
    • Customize your own stitch menu.
    • V menu stitches 13, for free-motion and baste.
    • Red frame around changed settings.
    • Automatic cursor advance when programming.
    • Overview of embroidery color blocks in help, including thread numbers.
    • Four new buttonholes in the B menu.
    • Selection of automatic or manual FIX in the SET menu.
    • Embroidery Position Reset, change position of embroidery in hoop
      and make note of position coordinates. Can be reset to position later.
    • The Hoop Selection pop-up menu now includes the Mega Hoop selection, and the program supports the Mega Hoop.
    • A pop-up tells you when itís time to change position on the Mega Hoop, which has also been added to the hoop selection menu.
    • Q foot on/off settings are added in the SET3 menu, and an alert
      message is displayed when the machine is started if the Q foot is
      active.
    • @ has been added to stitch alphabets and is now supported on embroidery font disks.
    • The disk icon on the main menu is rotated 90 degrees to indicate the proper disk insert direction.
    • Four new stitches added to the K menu.
    • The Users Guide is updated at every major software update. New pages are available to download from our web site.
    • New stitching order for satin buttonholes when using the Sensor
      Buttonhole foot. This will give a more balanced look to the columns
    • Four new stitches have been added. D46 (pin stitch), F15
      ("precision appliquè"), F16 ("frame" stitch) and V3 (basting stitch).
      When using V3, you can choose from manual feed until the foot is raised
      from the pedal and pressed again. If STOP is cancelled the machine will
      start automatically after a short pause for manual feed.
    • Support for the midsize hoop, 170 x 100 mm.
    • The total number of stitches in a color block are shown with the current stitch number.
    • 27 new exciting quilt stitches.
    • Cut can be programmed.
    • 18 new big beautiful Omnimotion stitches.
    • QuickFont Plus Support
    • Stitch C33/F6 (tapered satin) now indicates stitch part.
    • FIX can now be programmed together with stitches.
    • Length, width and elongation are now shown along with the stitch
      number in the lower left corner of the screen. When adjusted,
      the number is red instead of black.
  • 2,071 Answers
Just click below for the guide how to repair and put the needle.
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing regards,
Hopes it may help you;
Regards,
VOTIT
    Genius:
  • 3,422 Answers
HI,
Please click on the below link and follow the troubleshooting steps mentioned there:
http://www.cahe.nmsu.edu/pubs/_c/c-102.html
    Genius:
  • 1,239 Answers
Hi . The lock has a clamp arm which receives a threaded fastener and a needle tube arm which has a bore which receives the needle tab. The arms are integrally formed from stainless steel or other suitable sterilizable material. The lock is positioned about the needle tube and may be rotated relative to the needle tube retainer to a selected position and secured by tightening the fastener against the retainer. In this way, the tattoo machine is usable even if the retainer is broken or damaged.
  • 185 Answers
Remove the needle holder using a tool suitable for it and remove the needle and fix it again in the correct position and continue the stitching in zig zag .
Thank You
How to Change the needle position in XL2600i brother sewing machine?
The manual should be helpful:
Brother XL 2600 Operation Manual
FWIW, not all machines have a needle "position" function even though they can make a zig-zag stitch. The home position is the center and the zig-zag selector just sets how wide the stitch will be.
Dec 08, 2016 | Brother Sewing Machine - XL2600i
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
Model 930.Why is presser foot not lined up correctly?
Is your needle position centered? The round dial on the top right is a combination zig-zag stitch width selector and the center silver dial selects the needle position. If it is pointed at the #2, then the needle should be centered and something (probably the needle bar) has been knocked out of alignment on your machine (which would probably mean repair service).
Also, if the needle is hitting the presser foot, you probably have a straight stitch foot on your machine which requires the needle be centered. To do any decorative or zig-zag stitching, the presser foot needs to have a wide space for the needle to swing back and forth. The zig-zag foot is marked with a zero.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiP-OL76L7JAhWG9x4KHZ-6AgsQFghDMAM&url=http%3A%2F%2Fberninainstitches.com%2Fpdfs%2FBernina_Presser_Feet_Guide.pdf&usg=AFQjCNFihfp9MHOUl_6HmXxRrC8t3N32TQ&cad=rja
Dec 03, 2015 | Bernina Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
Needle position
Hmmm sounds like an issue I had/have with a singer stylist. There is a knuckle part that connects the zig zag mechanism to the needle bar. Mine had a pin that kept slipping out. When I took it apart (and lost the pin) I also discovered that the "round" holes the pin went into were work out and were more like ovals. The machine is now a parts machine.
Dec 09, 2012 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
May 14, 2010 | Bernina Bernette 75
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Sewing Machines Logo
109 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Derek Massey
Natasha Subko
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
