Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Pioneer SD-582HD5 - screen went black, no sound, however the power switch - red light on the front panel is still on
The TV was working fine and suddenly, the screen went black, no sound, however the power switch - red light on the front panel is still on. What could be the problem?
I had a fuse replaced for this same problem about 5 yrs ago. I would like to know if this could be the same problem and where is the fuse located and how can we replace this fuse?
  • 934 Answers
There are actually two fuses on the smps F201 (6.3a) & F202 (5a) if either or both of these are open the problem is not likely the fuse. What I try and tell customers is that a fuse being open is merely a symptom, never the cause.
This particular unit is plagued with poor solder connections which case the voltages to flutter violently and the symptoms you're experiencing... You would be wise to remove the power supply and replace it or have it rebuilt. There are a number of companies that specialize in rebuilding boards of this nature or any qualified shop could do it if they had the whole Tv, since they probably don't have a jig special for that unit.
In summary, check the two fuses above and just be prepared that replacing them won'y solve the problem and most likely just open the new fuses in a short time.
Bill
Premuim Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Posted on Sep 13, 2008
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
THE TV STAYS OFF
If the sound keeps working your probably just need a new lamp, if the sound does not stay on, you probably to get someone to fix the power supply.
Sep 02, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 Picture looks 3D with red and blue copies of images seperated on the screen..
Replace BOTH of your convergence ICs they are big black ICs will have part number on them if 110s use 180s.
Feb 18, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
My sd-582hd5 picture goes black
May 08, 2008 | Pioneer SD-582HD5 58" Rear Projection...
How to open pioneer sd-582hd5
from back good luck most problems are cold solder connections and i some models you have to replace three small caps in the video circuit
Oct 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Mar 28, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
295 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
