Question about Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range
Maytag burner turns off and on randomly
Our biggest burner (which we use most often) just recently started turning off by itself in the middle of cooking. Any ideas?
    Sergeant:
  • 409 Answers
From the sounds of it, it's the burner infinite switch.
Posted on Sep 13, 2008
TV just shuts off randomly. Any idea what the problem might be?
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself
Apr 09, 2015 | Samsung Televison & Video
Maytag LP Gas burner problem
are you sure the pin in the gas pressure regulator under the plastic cap and brass nut was turned 180 degrees to set it for propane gas?
Aug 20, 2012 | Maytag Dryers
What would cause a model number 37wd12 to turn itself on and off at random.
Is the remote doing it?...remove the batteries from it and see if it still does that
Feb 07, 2018 | RCA L37WD12 37 in. LCD HDTV
My Maytag Gemini stove started igniting all the 4 burners randomly by itself without the gas being on. I hadn't used it all day it was not wet, I checked thoroughly and it wasn't dirty. They all kept...
You will need a new switch harness part#12002789 and spark module part#74007397.
1. You can gain access to the switch harness by unscrewing 2x screws on each of the burners
2. The remove old wire harness and replace with new
3. Follow the wire from the harness it will lead to the spark module now replace it
Good Luck
Dec 07, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
Randomly turns itself off.
This is the point that you should bring your computer into your nearest tech support center. There is probably a problem with your hardware because of its age, or some physical damage has happened to it. This will be around a 100 dollar fix.
Apr 13, 2009 | Dell Inspiron 1525 Laptop Jet Black
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
Sealed Burner
Ralph, you need to look at the electrodes at the burners. They might be cracked or dirty. It's very hard to tell sometimes when they are cracked. The burner cap itself has to have a good ground and the wires going to the electrode should be on tight. You can eliminate the spark module by switching the right and left side burner wires at the module. Once you do that, if the right side works ok, but now the left doesn't, you can be pretty sure it's the module...Catriver..post back.
Mar 03, 2007 | Maytag MGR4451ADS Stainless Steel Gas...
Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range Logo
181 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
